Ping problems - whats going on? Seriously getting annoyed.
neil3045
Re: Ping problems - whats going on? Seriously getting annoyed.
I havnt read the original pages but have you got your computer wired to the router via ethernet cable?
Your cables are all fine? I once had a huge problem which went undetected because my ethernet cable was split INSIDE!
Try pinging your routers they should be returning ping of <1
Have you requested to have your interleaving switched off yet?
My pings are very stable even at peak times I can get solid green bars on mw2. These are my pings off peak:
Microsoft Windows [Version 6.0.6001]
Copyright (c) 2006 Microsoft Corporation.  All rights reserved.
Pinging bbc.co.uk [212.58.224.138] with 32 bytes of data:
Reply from 212.58.224.138: bytes=32 time=17ms TTL=121
Reply from 212.58.224.138: bytes=32 time=19ms TTL=121
Reply from 212.58.224.138: bytes=32 time=18ms TTL=121
Ping statistics for 212.58.224.138:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
    Minimum = 17ms, Maximum = 19ms, Average = 17ms
C:\Users\laura>
Taylor3
Thanks for the reply I appreciate it, can you help further?
My replies in green:
Quote from: neil3045
Yes my cables are all fine. (I only get the latency problem in the evenings round 5pm-12pm) So I can rule this out.
Can you explain how I can check this?  I don't know how to do it sorry 😕
What's this interleaving?  How do i request this?  Via a ticket?
C:\Users\laura>
Strat
Fixes: 565
Interleaving is a kind of error correction on ADSL and helps to provide a good signal under poor conditions.
However the downside is that it increases ping times, a disadvantage in gaming.
You can request to have it turned off in a ticket although if you can catch the eye of a Comms Team member....all the better. Wink Smiley
Ben_Brown
Quote from: dungeonmstr
4  te2-1.pcl-gw02.plus.net (212.159.1.114)  209.280 ms  174.660 ms  200.785 ms
5  te2-2.thn-gw2.plus.net (212.159.0.190)  14.824 ms  14.349 ms  15.040 ms
6  rt0.thdo.bbc.co.uk (212.58.239.25)  14.619 ms  14.324 ms  13.944 ms
7  212.58.238.133 (212.58.238.133)  17.677 ms  14.133 ms  16.025 ms
The routers and gateways such as pcl-gw02 give direct pings a lower priority than routing traffic, so at busy times it will appear that they are holding up your traffic when they aren't.
You can see from the final destination time of 17.677ms that this apparent 'spike' has not impacted your connection (17ms to BBC is what I would be very happy with).
bobpullen
Fixes: 316
How much longer can this possibly go on for? It's a waste of time even trying to play an FPS game online competitively. I can't believe my gaming habits are being decided for me by my ISP.  Roll_eyes
Consistently high pings above 200ms doesn't seem synonymo9us top me of the problems we've been having with the network. Just a thought but are you running any other applications in the background as you're gaming. I've checked you data transfer figures and there were quite a few days throughout November where you've uploaded in excess of a gigabyte of data (sometimes close to 2GB). To do that you'd need to be going flat out for at least a third of the day. If you're doing this whilst your gaming then it's going to have a detrimental impact on your gaming.
@Taylor3, your account looks OK. Are your pings consistently high or do they intermittently spike as you're playing?
dungeonmstr
Quote from: Bob
The occasion when the pings were over 200ms was a one-off, and unrelated to anything else running on my network.
Bandwidth-intensive tasks on my network are scheduled to run overnight, through to midday (basically any time in which our peer-to-peer bandwidth isn't throttled). With an upload cap of 37kbps, which is the maximum I ever set, it only takes 12 hours to upload 1.6GB, which seems about right (considering the overheads of other applications) for the usage figures you provided. I usually don't game during this period, but if I do, I stop said tasks first. I even go as far as removing all my computers from the network when I'm gaming, to be absolutely sure that they are not interfering.
My entire set up right now is identical to how it was with my previous ISP. There was no great variation in latency like there has been over the past few weeks with Plusnet.
Fortunately, over the past few days things have been relatively good when I've checked it out (others have reported the same) and so hopefully we are nearing the end of what has been a very unsatisfactory period. I appreciate all the feedback we receive and would happily say that Plusnet have excellent levels of communication and support across all sorts of mediums.
neil3045
Talor I would still raise a ticket to have your interleaving turned off: https://portal.plus.net/wizard/index.html?Ea82ChdSAqqwtYJcjZV%2Fjl8BeHfnW7ogQYILXVCBFsnFyRVJeEpVZrrG...; It made a huge difference to my evening pings, the quiter your line the better the result!  Wink
KaotiK
After good pings for the last week now, this evening high pings are vack Sad gonna try reset router to switch gateway to see if it helps.
bonmeggie
Little higher tonight yeah but overall pretty good for the last few days, keep it up Plusnet! Cheesy
dungeonmstr
It was OK for me last night (this morning) between 00:00 - 03:00.
KaotiK
Ping up again right now on thn-ag2.  gateway., its like 330 on wow. But needa get interleaving turned off. just keep never bothering. wud prolly drop it enough but still would be high. last night gateway change worked so il try it today, but usually monday is the worst day 😐
KaotiK
restarted  to try diff gateway and still terirble high ping on wow. The usual monday mess. just hate the fact for the past week it seems everythings going back to normal then this happens. Hope its not just me 😐
Myst
No its not just you.  Angry
After a week of pretty reasonable pings (other than a reboot very occasionally  to change gateways) its now back to where it was a couple of weeks ago
1    <1 ms    <1 ms    <1 ms  192.168.0.1
2    66 ms  209 ms  189 ms  lo0.plusnet.thn-ag2.plus.net [195.166.128.93]
3  127 ms    75 ms    71 ms  vl604.thn-gw1.plus.net [84.92.4.169]
4  131 ms    71 ms  125 ms  lonap1.enta.net [193.203.5.134]
5    77 ms    93 ms    65 ms  Transit-enta.KillerCreation.co.uk [62.249.255.]
6    81 ms    73 ms    65 ms  217.146.94.6 [217.146.94.6]
7    74 ms  103 ms    75 ms  Service.alpha-networks.co.uk [217.146.93.119]
Trace complete.
bobpullen
Fixes: 316
Hmmm, the network's as well balanced as it was last week (if not more so), and the changes last Thursday should also have helped. Monday is our busiest night but regardless this still concerns me.
@Myst is it WoW you're having difficulties with too?
Myst
No Bob
Mainly MW2 on pc at present but affecting both CoD4 and 5 too. Last night with MW2 instead of connecting once ping range was 80ms it was reaching 170+ before finding a game, once in it was unplayable.
It is my dedicated server that i ping too as a rule although i get similar stats for others i test.
