Phantasy Star Online 2
Pyrii
There appears to be a problem recently with people outside Japan accessing the website (http://pso2.jp) and servers for this game.
There are many theories flying around, including the idea that there's an IP-ban from SEGA. But I think the best one is that SEGA JP's PSO2 servers have been blacklisted on a blacklist that most ISPs around the world sign up to.
From http://www.pso-world.com/forums/showpost.php?p=3156561&postcount=11
More than likely, the connections to the servers are being blacklisted automatically by companies/services of whom are tasked with monitoring the status of servers around the world.
The way it works is that the backend providers all subscribe to services that monitor server status (think the adblock subscription list when you first install the addon). The services will monitor [Censored]. When a server is deemed a threat/problem either by DDOS, Infection, Spam issues, Hacking, etc, then the service will blacklist the server and update it's list of which the backend providers will automatically block connections to that server.
According to highest level tech support of Cox (which apparently is a Level 2 Backend provider itself and provides a lot of infrastructure itself), this is most likely what happened. The DDOS got Sega's servers blacklisted by the server-monitoring service and as such, the backend providers who subscribe to this service automatically blocked connections. ISPs who rely on the backend providers are inherently affected by this.
I asked if Sega can request for these blocks to happen and I didn't get a clear answer, but I'm lead to believe that he's implying that it all happened automatically. Sega, however, can manually get itself de-listed early if it takes the initiative.
However, if Sega doesn't do such a thing, the blacklist will remain until the server-monitoring service discerns that Sega's servers are no longer an issue, meaning, the automated service has to say that, "Okay. Looks like the coast is clear. Kgo."
How long that will take, Cox couldn't say because the process is automated. But if Sega did do their job, then over the course of time we should see ourselves able to play once again as the service will stop blacklisting Sega's servers and that would be reflected by our ISPs.
(This also leads me to believe that Verizon is not legit, and is [Censored] because it's subscribed to a blacklisting service that sucks at detection. That or is actually IS legit, and it updated its info mad fast and [Censored]. I personally believe the prior over the latter.)
tl;dr - Cox says this is more than likely a backend provider issue in the sense that the server-monitoring service has automatically blacklisted Sega's servers due to DDOS nonsense and that everything will go back to normal whenever the service detects that the DDOS nonsense is no longer a thing. When that is, however, cannot be determined at this time. Sega can get it fixed early if they so please, but as far as the conversation went, it was implied that Sega did not / cannot actually trigger the blacklist themselves.
Take this as you will guys.
Me?
I'm like now 99% sure its not an IP block and we're just victims of automation and SegaC being SegaC.
EDIT: Cox did mention using a website like Safehaus.org in order to find out if the servers are indeed blacklisted, but that's not something us mere mortals can access freely, unfortunately. So I have nothing concrete to offer outside of "he-said she-said" with the highest level tech support at Cox.
I myself am noticing tracerts to sega.jp and sega.co.jp go through to Japan, but tracert to pso2.jp dies at Plusnet's routers.
C:\Users\Pyrii>tracert pso2.jp
Tracing route to pso2.jp [210.189.209.8]
over a maximum of 30 hops:
 1    <1 ms    <1 ms    <1 ms  192.168.254.254
 2    21 ms    53 ms    24 ms  lo0-central10.ptw-ag03.plus.net [195.166.128.197]
 3    20 ms    20 ms    20 ms  link-b-central10.ptw-gw02.plus.net [212.159.2.154]
 4     *        *        *     Request timed out.
 5     *        *        *     Request timed out.
 6     *        *        *     Request timed out.
 7     *        *        *     Request timed out.
 8     *        *        *     Request timed out.
 9  ^C
C:\Users\Pyrii>tracert sega.co.jp
Tracing route to sega.co.jp [157.109.161.11]
 2   349 ms   552 ms   739 ms  lo0-central10.ptw-ag03.plus.net [195.166.128.197]
 3    21 ms    20 ms    20 ms  link-a-central10.ptw-gw01.plus.net [212.159.2.152]
 4    20 ms    20 ms    20 ms  xe-4-3-0.ptw-cr01.plus.net [212.159.0.244]
 6    88 ms    88 ms    86 ms  100ge1-1.core1.nyc4.he.net [72.52.92.166]
 7   153 ms   150 ms   149 ms  10ge10-3.core1.lax1.he.net [72.52.92.226]
 8   153 ms   153 ms   153 ms  pacnet.10gigabitethernet2-3.core1.lax1.he.net [216.218.223.206]
 9   270 ms   270 ms   270 ms  ip-202-147-0-52.asianetcom.net [202.147.0.52]
10   267 ms   267 ms   268 ms  ge3-1-0-0.gw3.nrt4.asianetcom.net [202.147.0.55]
11   268 ms   268 ms   268 ms  gi6-0-0.gw1.nrt4.asianetcom.net [202.147.0.229]
12   268 ms   268 ms   268 ms  xe-1-0-3-0.gw2.nrt4.asianetcom.net [202.147.0.237]
13   268 ms   268 ms   268 ms  MBI-0041-VET-0003.asianetcom.net [203.192.149.238]
14   256 ms   256 ms   256 ms  ae0.transit1.nihonbashi.vectant.ne.jp [163.139.128.158]
15   268 ms   268 ms   268 ms  116.91.136.110
16     *        *        *     Request timed out.
17     *        *        *     Request timed out.
18     *        *        *     Request timed out.
19     *        *        *     Request timed out.
20     *        *        *     Request timed out.
21     *        *        *     Request timed out.
22     *        *        *     Request timed out.
23     *        *        *     Request timed out.
24     *        *        *     Request timed out.
25  ^C
Could someone check the blacklist for PSO2 JP's servers and see if they could be removed so access to the game could be returned?
pso2.jp : 210.189.209.8
pretty much all PSO2 JP's servers: 210.189.208.0/24
4 REPLIES 4
Pyrii
Re: Phantasy Star Online 2
There are DNS mappings for all PSO2 JP servers
gs<abc>.pso2gs.net = 210.189.208.<abc>
for example:
Tracing route to gs040.pso2gs.net [210.189.208.40]
 2    21 ms    22 ms    23 ms  lo0-central10.ptw-ag03.plus.net [195.166.128.197]
 9  ^C
I guarantee you the servers are not "In Maintenance". Apparently the client will say that even if the server is offline.
Pettitto
Fixes: 5
Sorry for getting back to you so late.
I've just had a chat with one of the Network guys here and we're pretty sure this is something controlled by Sega.
http://www.pso-world.com/forums/showthread.php?t=220443 - suggests the service is Japanese only. If you've got a Twitter account, you might be able to contact them directly at https://twitter.com/sega_pso2
It does seem as if the site is not working for any non Asia Pacific addresses 😕
Unfortunately it's well outside of our control. You might benefit from trying to get hold of them on Twitter or on the above Forum.
Pyrii
How come none of the traffic appears to be leaving plusnet's backbone then? If SEGA was blocking traffic, I'd expect for the connection to at least transit to Japan first.
Unfortunately SEGA have repeatedly shown they have no clue WHAT they are doing.
Pettitto
Fixes: 5
I've found a few useful links which may help. It looks as though they've suffered a DDoS attack.
http://www.dslreports.com/forum/r29370409-Dslextreme-blocking-access-to-phantasy-star-online-2
http://pso2blog.wordpress.com/
I'm hoping they get the issue resolved soon for you, I can imagine it's frustrating.
