Packet loss and high latency
turbointernet99
Hello. I am hoping you can help me. For the past few weeks I've noticed that I have been getting less performance from my internet due to packet loss and high latency.
I managed to set up a monitor for you to have a look.
https://www.thinkbroadband.com/broadband/monitoring/quality/share/abb803dc4244df4a66a5f57c6cbeb3a5d3913f82-21-07-2018
Now i really ain't super savvy with the details, but from what you can see there is defiantly some sort of issue.
Can you please assist on what I need to do to get it sorted.
Thanks.
27 REPLIES 27
adamwalker
Fixes: 221
Re: Packet loss and high latency
Cheers for running the monitoring on that. The link is only showing about 4 hours from a few days ago. Can you let us know when you've been able to run that for a longer period as that could be a lot more revealing to us.
Also have you tried running a speed test to see if your downstream speeds are any lower than usual?
 Adam Walker
turbointernet99
Hi, and thanks for the reply.
I could only get the monitoring information by putting my ps3 into dmz mode and turning off all my firewalls, as I could not find any other way of doing it. I don't know if using that to monitor my connection will make any difference to the true facts, but I felt unsafe leaving all my firewalls open for a long period of time. (not sure if it is safe or not)
I have checked my speeds and they all look like they are running to my plans specification, and I have never had this problem before.
Could it be a router issue ?
I have tried everything known to man and I only stumbled over this forum a few hours ago.
MasterOfReality
Fixes: 57
Hi turbointernet99
Are you noticing this when connecting via WiFi or through a LAN cable?
turbointernet99
Sorry, I should of stated that information in the OP. This is all happening while connected via LAN.
The graph that I showed you was information regarding the packet loss and high latency during none activity (No streaming, videos, gaming etc.)
It just really confuses me why I am getting this problem after countless years and internet peace.
adamwalker
Fixes: 221
As you've mentioned you see packet loss even when the connection isn't in use is there a possibility of you trying another router out on the line to see if the same thing happens?
 Adam Walker
turbointernet99
Ok, got my self a different router to test and currently seeing this -
My Broadband Ping - internet
Not as bad. Is this normal to see this spike ?
This graph is ongoing also, so this will keep giving info.
Kelly
Fixes: 9
Which spike are you using referring to?
That looks like a very normal graph,.  The yellow latency jumps are just when you are (probably) using the connection?
Kelly Dorset
Ex-Broadband Service Manager
turbointernet99
Hello, and thanks for the reply.
The spike I was referring too was the huge one with the packet loss.
I am also seeing and experience packet loss during usage and I know that it is not normal.
The connect is not heavily utilised. It’s used for general web usage and online gaming.
Fixes: 1,600
Hi @turbointernet99
Trying something here, could you switch your router off for 5 minutes then back on?
Let us know how your connection feels following this.
Cheers -Anoush
turbointernet99
Hi, I can’t at the moment, but I’ve already tried that a number of times which had no effect.
Fixes: 1,600
No worries. I've made a change our side.
When you can I'd recommend rebooting once more and let us know how it goes.
turbointernet99
Ok, thank you. I won’t be back in the house till late, but I’ll reboot it and give it a whirl.
Could I please ask what you have done ?
Fixes: 1,600
I've added a static IP to your account changing the way your service routes across our network.
turbointernet99
Ok, thanks. I’ll monitor it for the next few days and let you know.
