Packet Loss when Gaming
delta3
Edit: See further down for issue.
6 REPLIES 6
Gus
Re: Please add Counter Strike: Global Offensive to defined games
It already is, uses same ports as Counter-Strike.  So probably routing issues to the specific server/s.  So run a ping trace to it during any time it's showing a high ping, to find out where it is slowing down
FTTP 500 regrade from Tues 28th November
delta3
The ping never goes up, it's just that my bullets don't register on other players. I did a ping test though as you suggested Gus, with interesting results:
This is from a Pinion server (the ones I can use):
and this is from an official Valve server (the ones where nothing hits):
I tried a few more of each, and I was getting the same green healthy results with Pinion other servers and the same red 'LOST' messages with other Valve ones too. So there's obviously a communication error happening somewhere. Any ideas?
Edit: Incidentally my in-game packet loss with net_graph 1 enabled in console is always minimal or non-existent after initial connection is established, regardless of which server I'm connected to
Gus
You need to run the ping test from your pc, using a site doesn't give routing from you but from that site.
delta3
ahh sorry. how's this?
Pinion:
Valve:
Tried an additional 3 Valve servers and they all timed out as above, even when set to 9000ms  Undecided
delta3
and a traceroute:
Pinion:
Valve:
delta3
Just ran an ICSI Netalyzr test and it came up with the following problems:
Is there any way to address these, particularly the bottom one which looks (to my untrained eye) like it may well be the source of the problem?
