Packet Loss when Gaming
delta3
Edit: See further down for issue.
6 REPLIES 6
Re: Please add Counter Strike: Global Offensive to defined games
It already is, uses same ports as Counter-Strike.  So probably routing issues to the specific server/s.  So run a ping trace to it during any time it's showing a high ping, to find out where it is slowing down
Unvalued customer since 2001 funding cheap internet for others / DSL/Fibre house move 24 month regrade from 8th May 2017
delta3
The ping never goes up, it's just that my bullets don't register on other players. I did a ping test though as you suggested Gus, with interesting results:
This is from a Pinion server (the ones I can use):
and this is from an official Valve server (the ones where nothing hits):
I tried a few more of each, and I was getting the same green healthy results with Pinion other servers and the same red 'LOST' messages with other Valve ones too. So there's obviously a communication error happening somewhere. Any ideas?
Edit: Incidentally my in-game packet loss with net_graph 1 enabled in console is always minimal or non-existent after initial connection is established, regardless of which server I'm connected to
You need to run the ping test from your pc, using a site doesn't give routing from you but from that site.
delta3
ahh sorry. how's this?
Pinion:
Valve:
Tried an additional 3 Valve servers and they all timed out as above, even when set to 9000ms  Undecided
delta3
and a traceroute:
Pinion:
Valve:
delta3
Just ran an ICSI Netalyzr test and it came up with the following problems:
Is there any way to address these, particularly the bottom one which looks (to my untrained eye) like it may well be the source of the problem?
