PSN disconnects
freedomofspeech
PSN disconnects
for some bizare reasons i get disconnects from the Playsation network - either when i amplaying a game or streaming a film it will disconnect
the actually adsl connection does not disconnect and inever had the problem with my previous isp - sky
Plusnet Staff
Plusnet Staff
Fixes: 5
Re: PSN disconnects
Hey,
Are you connect over Wireless or Ethernet?
If you're connected over Wireless, can you try it with an Ethernet, just to see if this resolves the problem?
If it does, we can look at changing some of your Wireless Settings to try and improve your experience.
Chris Pettitt
Cloud Environments Engineer
freedomofspeech
Re: PSN disconnects
its ethernet connection that i have
as i say the psn disconnects from the service but the adsl remains connected
it was happening alot so maybe there was an outage on the psn - seems to have dies down a bit
Plusnet Staff
Plusnet Staff
Fixes: 5
Re: PSN disconnects
Quite possibly.
Let us know if you have any further problems with it.
Chris Pettitt
