PS4 Nat type 2 & strict
- Gaming
- PS4 Nat type 2 & strict
05-01-2014 7:53 PM
Hi
I am using a Thomson TG585 V8 and have tried all the port forwarding advice. When i test the port using PFPortChecker it tells me that the ports are not open or not reachable. Tried putting the PS4 into DMZ but couldnt connect to the net. Been at this all day, I have noticed on some sites people have pointer towards the router, if so can anyone recommend a replacement or further instructions on a fix
cheers and thanks
cheers and thanks
4 REPLIES 4
Re: PS4 Nat type 2 & strict
08-01-2014 6:08 AM
Anyone ? Is it straight forward to set up my own purchased router with Plusnet ?
08-01-2014 8:37 PM
have you disabled upnp in the router and the ps4.is it one game you are having problem with...........
08-01-2014 8:46 PM
http://community.plus.net/library/gaming/increasing-gaming-compatability-with-the-thomson-tg585v8-xb... even though it says ps3 should work for ps4..
09-01-2014 10:07 PM
1st class sully72, now nat type open on 1st attempt, thankyou for your reply
