PS3, windows media server and speedtouch 780WL
- Gaming
- PS3, windows media server and speedtouch 780WL
18-12-2007 9:50 PM
has anyone with the same setup as me been able to access files from a PC on the PS3.
I've gone through the setup and rebooted several times but the PS3 still can't find my media server.
My PC plugs into the router through USB, the playstation through LAN.
Now that the PS3 can play DIVX, I'm very keen for this to work, it would save me having to burn onto a CD or DVD to watch season 2 of heroes
Re: PS3, windows media server and speedtouch 780WL
19-12-2007 12:38 AM
You can install Linux on a PS3 apparently.
see http://en.wikipedia.org/wiki/Linux_for_PlayStation_3
This would certainly let you access networked files.
But any PC can play DivX format can't it?
Why not simply use the PC?
19-12-2007 12:13 PM
Now the anomaly and part of the answer to your question, we tried testing all three computers to provide media (video, music and pictures) to the PS3 by using Media Player 11 as the ‘Media Server’. On two of the computers it worked ‘out of the box’ as they say, we just followed the instructions on setting up MP11 and the PS3 was able to access the media and play anything just fine. However on the third computer we never got it to work, we don’t know why, and there seems no reason for it not too but everything we tried failed.
So it might not be anything you are doing it might just be one of those computers. When it does work its great and the PS3 displays pictures on the TV fine, it also plays all our music via the surround sound system (linked via the TV) with pretty good quality. The remote control, (if you have one), is super for selecting things and again works just as it should. I hope you can get it to work because it’s brilliant when it does.
Regards, P.
19-12-2007 4:34 PM
I'm thinking installing SP1 screwed my WMP 11 media share though seeing as thats the only major change i can think of...
08-01-2008 8:45 PM
Quote from: dubiez I've gone through the setup and rebooted several times but the PS3 still can't find my media server.
Not ever used a usb connection to a router, but does your pc that is connected via usb have an IP allocated? Can you ping the ps3 from your pc..
Do you have a firewall enabled on your pc.. that is normally a big culprit... otherwise it may very well be a config issue with the media server...
10-01-2008 1:46 PM
Quote from: axisofevil But any PC can play DivX format can't it?
I would prefer to chill out on the sofa and watch divX through the 50inch plasma
13-01-2008 9:57 PM
I feel uneasy about installing Linux on my PS.
There was some stuff about having your PC as a server and linking up with your PS via typing the i.p over the Internet but this would obviously use up your bandwidth and considering moving about large files fairly frequent is not ideal.
Would be interested to hear the solution I have similar setup as Axis.
14-01-2008 1:56 PM
- I'm running vista with media player 11 and the setup took approx 2mins.
- Open media player 11, click on library then media sharing. Tick the box and it will show 'unknown device'. If you are on vista, click 'unblock' if prompted with a firewall notification
- Fire up your ps3, goto Video and do a search for a 'media server'
- You will see a request on the PC for a 'unknown device' to connect, click to allow
Sit back, browse you pc's contents and watch those divx's which play flawlessly!
Ensure your ps3 and pc are on the same subnet and things should fly!
One happy punter here, at last Sony have started to unleash the shackles...
15-01-2008 11:07 PM
I also hear that Nero media home works well with the PS with a few more features.
16-01-2008 10:09 AM
16-01-2008 11:05 AM
Also if you have problems connecting to your PC it may be a problem with DRM. If you see my post above we had problems connecting one of our three Pc’s, this was because of a DRM conflict on the PC and was solved by deleting a hidden DRM folder on the PC.
Regards, P.
19-01-2008 1:32 PM
