PS3 connection error 80029020, using Thompson 535
- Gaming
- PS3 connection error 80029020, using Thompson 535
20-09-2011 1:24 PM
Hi, I just got Plusnet last night with standard Thompson router. All is working fine but:
I connected the PS3 and am able to connect to PSN. However when I test the connection everything seems right, Nat type 2 etc, but the speed calibration fails and I get the error message 80029020.
Weirdly though I was able to connect to friends playing Dead Island last night but it froze quite quickly,
I have just done the standard set up so far, because I don't really know what I am doing! Any advice would be appreciated.
4 REPLIES 4
Re: PS3 connection error 80029020, using Thompson 535
20-09-2011 1:49 PM
Welcome to the forum stratattack.
What's your internet like generally, do a BT Speedtest and post the results.
Do you have uPNP enabled on the router and PS3?
21-09-2011 4:53 PM
Thanks Strat. I mucked about with router settings last night, assigned a static address, attempted to put in DMZ etc. I had no luck so returned the settings to normal and it worked! I'm not really sure why but i am very happy. The connection is strong and constant so very pleased with plusnet at the moment. See you online some time
21-09-2011 10:49 PM
Quote from: stratattack See you online some time
With a forum name like stratattack I should probably say "I hope not"
Anyway it'll be BF3 in about a month so maybe see you there
22-09-2011 1:42 PM
I assure you the name is purely coincidence!
I am a COD guy but I might have to give bf a go this year.
- Gaming
