PS3 USB Headset
Fixes: 1,474
PS3 USB Headset
Does anyone use a wired usb headset with their PS3?
There are too many conflicting threads on different forums about them so just wanted a good solid recommendation 🙂
Thanks,
2 REPLIES 2
JimP
Re: PS3 USB Headset
I use a Logitech notebook headset, and it's fantastic!
had to buy a USB extension cable as the lead is only 1.5m long
Have used a bluetooth too on the PS3 and find the USB one much better, connection is better, clarity is better and the battery doesn't run out every 30 minutes!!!!
HTH
Jim
Fixes: 1,474
Re: PS3 USB Headset
Thanks Jim, got a logitech one that was done for the PS2, has a 6ft cable with volume and mute button.
Works really well, can now avoid the rap playing little kiddies on COD4 🙂
