PS3 System Update
- Gaming
- Re: PS3 System Update
PS3 System Update
01-04-2010 8:11 PM
Yeah I know it's probably from Aka..what's it's name but really.....
01-04-2010 8:31 PM
Other option? do it through the night And thats the update im on about,nowt cheeky mind
01-04-2010 8:38 PM
It took me 3mins to download through the console.
01-04-2010 8:53 PM
40KB/s from the ps3 website and even slower via the ps3
FUCK!
01-04-2010 8:55 PM
Yet Plusnet still maintain that there's nothing throttled about the PSN. Yeah right, pull the other one it has bells on it.
01-04-2010 11:42 PM
Quote Yet Plusnet still maintain that there's nothing throttled about the PSN
PSN wont be throttled at all, however it probably uses a content distributer (e.g. Akamaii (iirc)) - which means the downloads will listed as 'download servers' - and therefore be shaped accordingly to the package your on.
01-04-2010 11:49 PM
Quote Should of gotten an xbox 360
whispers * XBL uses limelight CDN and so to gets rate limited on downloads an updates
02-04-2010 12:05 AM
It came down heads
02-04-2010 4:27 AM
Quote from: Matt_2k34 PSN wont be throttled at all, however it probably uses a content distributer (e.g. Akamaii (iirc)) - which means the downloads will listed as 'download servers' - and therefore be shaped accordingly to the package your on.
Then why is the same file is downloaded in minutes on the PC yet only gets to 3% after two hours on the PS3? Surely if it's coming down from the same place on the same connection, and router session, it would be the same on both machines.
02-04-2010 7:52 AM
Quote from: Asbo
360 game updates are not allowed to be more than 5MB. MS restrict game devs to 5MB which helps. Some ps3 game patches are over 50MB. When I was with Plusnet I just stopped playing my PS3 because I never had time to update it, during the day it was way too slow and at night, well I'm not nocturnal.
02-04-2010 2:11 PM
Quote it would be the same on both machines.
not necessarily, both devices will handle the traffic differently, its quite possible the traffic on the PC is being routed incorrectly, and your getting more speed than your supposed too - shame you cant run a wireshark on the PS3 eh?
And size really does matter, unfortunately PSN updates *are* massive...
02-04-2010 2:36 PM
just bridge the 2 network interfaces and hook you console up and run wireshark
http://www.twiggymac.plus.com/0x80%20oxm%20report.pcap
xbox cap from time ago when i was helping PN get the streaming vids classed right as they was being picked up as 0x60 gold plated (download servers)
02-04-2010 3:35 PM
Sony contract out the hosting of Store content downloads and Firmware updates to another company called Akamai
http://www.akamai.com/html/about/press/releases/2006/press_121906a.html
