PS3 - Quantum Of Solace
- Gaming
- PS3 - Quantum Of Solace
18-01-2009 5:47 PM
My son has just got this game and had been playing on-line. He seems to be getting a few disconnections, mainly this afternoon (Sunday). Would someone from PlusNet mind checking that the game is set up correctly for traffic prioritisation.
Thanks - Bob
Thanks - Bob
6 REPLIES 6
Re: PS3 - Quantum Of Solace
19-01-2009 11:00 AM
Hi Bob,
I've asked Carl to check if it's one that he's tried.
I can see that you had a disconnection mid-morning yesterday. Were the game disconnections happening before or after that?
19-01-2009 6:06 PM
James, the disconnection on Sunday was when one of my sons kicked the mains plug out on the router !! (don't ask).
We've only had the game since Thursday and most of the disconnections were on Sunday morning. We've had a couple this evening though.
I posted a question on a PS3 games forum and opinion seems to be divided on whether there is an issue with the game. I just wanted to check that it was setup ok at your end.
Thanks again - Bob
Thanks again - Bob
20-01-2009 10:19 AM
Thanks Bob,
If you could get a ticket raised with port numbers and servers, we'll happy look at getting it added to the defined games list.
20-01-2009 12:51 PM
http://activision.custhelp.com/cgi-bin/activision.cfg/php/enduser/std_adp.php?p_faqid=22076&p_create...
What ports does this game use?
Question
Answer
The game uses the following ports:
TCP - 80, 443, 3074, 5223
UDP - 3074, 3075
The same ports as CoD4 and CoD:WaW
I double check our configuration ....
Question
Answer
UDP - 3074, 3075
20-01-2009 2:41 PM
I have checked the configuration and all seems in order, HTH
20-01-2009 6:20 PM
Thanks guys, I guess it's a game issue then. Not a big problem as it doesn't seem to happen very often.
Bob
Bob
