PS3 Nat type HELP
- Gaming
- PS3 Nat type HELP
Re: PS3 Nat type HELP
09-11-2011 9:59 PM
I'm pleased to hear you got it working, I will add that to my guide for PS3 users.
09-11-2011 10:01 PM
09-11-2011 10:05 PM
Odd about the static IP thing i know, but this solution works and is simple enough just a case of copying and pasting as you see it.
Thanks for all help and solutions here though!
09-11-2011 10:08 PM
Quote from: sandmatt
You're very welcome sandmatt
It's been a frustrating one... But we've got there! and Your little tutorial is part of mine now, with your name on it
10-11-2011 6:50 AM
10-11-2011 9:36 AM
Guide to obtain OPEN NAT in PS3 Black Ops with Thomson TG782T Modem
Step 1- On your PC go to start click on run copy and paste this command. telnet 192.168.1.254 (press enter)
- When i put the password as blank it says invalid combination and immediately shuts the window down....
10-11-2011 9:57 AM
I have always had this issue with my ps3. My xbox doesnt need any mucking about its just fine, but the ps3 and in paticular COD seems to not get on with Plusnet and/or this type of router.
I would be so happy if this could be sorted once and for all.
Also could someone confirm this fix works with MW3?
10-11-2011 9:58 AM
Quote from: leighbaldwin Sorry for the many many posts but have been looking and searching and found this:
I copied this over from another forum. You need to enter the right combo for you router: your username, usually admin and whatever you have the router password set to, should be on a sticker provided by plus net.
10-11-2011 10:03 AM
Quote from: johnnybebad2000 Will this fix work with the Thomson Tg585 V7 router?
It does work with MW3. I know it says black ops but that was what the original fix was for, MW3 uses the same ports.
10-11-2011 10:08 AM
10-11-2011 10:43 AM
Good, im starting to get somewhere now - can i ask if this works with the Tg585V7 router Plusnet provided me with?
If not then can plusnet send me the newer Thomson TG782T router please so i can fix this once and for all - been a year of trying to get this fixed.
10-11-2011 11:34 AM
The username for the telnet session will either be Administrator or admin and the password may either be blank or the serial number of the router starting with CP
Hope this helps,
Regards,
Matt
10-11-2011 12:39 PM
Justy a final note on the PS3 guide, if you have windows 7, then you need to go into, start, control panel, programs, then into turn windows features on and off and in there turn the telnet client on and you should then be able to use the command. As I had problems with this to begin with and sorted it this way.
Graeme
10-11-2011 1:11 PM
Quote from: gpavlovic
Graeme
Very important to do this
10-11-2011 1:18 PM
http://community.plus.net/library/uncategorized/increasing-gaming-compatability-with-the-thomson-tg5...
We've expanded the port range so that games which do not adhere to the standards will still work.
Thanks,
Matt Turner
