PS3 Internet Speeds
- Gaming
- Re: PS3 Internet Speeds
PS3 Internet Speeds
22-02-2013 2:26 AM
I thought google was my friend but apparently not - does anyone know why when you do an internet connection test on a PS3 the speeds recorded are so low? Mine is wired through a powerline and while I would expect slightly slower speeds it is losing 50Mbps somewhere.
2 REPLIES 2
22-02-2013 8:17 AM
Think this has been reported before and turned out to be the inbuilt speed tester, using a browser based one like speed test.net provided more realistic results.
22-02-2013 3:27 PM
Yep, mine does the same. Use the browser and find a speed test that works and you'll see that it's not actually struggling for speed.
