PS3 HD Swap.
- Gaming
- PS3 HD Swap.
PS3 HD Swap.
27-08-2014 7:59 PM
It wouldn't work on mine because it needed a huge update (size unknown) and it told me I didn't have enough space on my drive (it is a 120GB drive with 9GB of available space).
So in response to this and space needs in general I have ordered a 500GB replacement.
I have read a number of procedures on various sites regarding a drive replacement and none so far have given me the confidence that I won't be losing some data.
Has anyone done this swap to their satisfaction? If so I would be interested to hear about it.
Re: PS3 HD Swap.
27-08-2014 8:31 PM
Re: PS3 HD Swap.
27-08-2014 8:38 PM
I really must get back into playing games again sometime
Re: PS3 HD Swap.
27-08-2014 9:25 PM
Re: PS3 HD Swap.
27-08-2014 11:45 PM
Re: PS3 HD Swap.
28-08-2014 8:38 AM
Re: PS3 HD Swap.
28-08-2014 9:20 AM
Re: PS3 HD Swap.
28-08-2014 7:15 PM
Re: PS3 HD Swap.
28-08-2014 7:59 PM
Re: PS3 HD Swap.
29-08-2014 6:10 PM
The swap-over took longer that expected due to the lack of a crucial piece of information.
I downloaded the latest firmware and put it on a USB stick as per various sites' guidelines.
The process failed, I placed the file on a CD, it failed.
Then I found a site which blew the cobwebs off an old memory.
The PUP file doesn't go on the USB stick, it goes in a folder called UPDATE within a folder called PS3 on a USB stick.
When I did this everything worked fine, the HD was formatted and installation was completed.
PS I have since found a reference the folders on a Playstation site page after a bit of digging.
