PS3 HD Swap.
Strat
Fixes: 565
PS3 HD Swap.
I have a PS3 and the grandson stayed last night and brought his copy of GT6 to play.
It wouldn't work on mine because it needed a huge update (size unknown) and it told me I didn't have enough space on my drive (it is a 120GB drive with 9GB of available space).
So in response to this and space needs in general I have ordered a 500GB replacement.
I have read a number of procedures on various sites regarding a drive replacement and none so far have given me the confidence that I won't be losing some data.
Has anyone done this swap to their satisfaction? If so I would be interested to hear about it. Smiley
9 REPLIES 9
Fixes: 1,483
Re: PS3 HD Swap.
I've swapped mine without issue, backed up the data onto another drive through the UI whacked in the new one and restored.
picbits
Re: PS3 HD Swap.
I repaired the one I got given, put it under the stairs a year ago and not turned it back on since  Cheesy
I really must get back into playing games again sometime  Grin
Strat
Fixes: 565
Re: PS3 HD Swap.
Thanks guys.
wo0x
Re: PS3 HD Swap.
Just be careful with the blue screw. It's made of plasticine... Apart from that it's all very easy.
Strat
Fixes: 565
Re: PS3 HD Swap.
Yes I've read about the soft screws involved but I have a 4" angle grinder handy in case of problems Wink
Fixes: 1,483
Re: PS3 HD Swap.
I have the original fat ps3.. my screws weren't fragile
picbits
Re: PS3 HD Swap.
One of the PS3 models has a case screw that is shorter than the rest - if you put the longer screw in the hole it will mess up the PCB inside the unit.
Strat
Fixes: 565
Re: PS3 HD Swap.
Thanks for the tip DomS Smiley
Strat
Fixes: 565
Re: PS3 HD Swap.
I'm just finishing off the HD replacement by restoring my backup, a 3 hour task.
The swap-over took longer that expected due to the lack of a crucial piece of information.
I downloaded the latest firmware and put it on a USB stick as per various sites' guidelines.
The process failed, I placed the file on a CD, it failed.
Then I found a site which blew the cobwebs off an old memory.
The PUP file doesn't go on the USB stick, it goes in a folder called UPDATE within a folder called PS3 on a USB stick.
When I did this everything worked fine, the HD was formatted and installation was completed.
PS I have since found a reference the folders on a Playstation site page after a bit of digging.
