PS3 GT5 Prologue Connection Problems
- Gaming
- PS3 GT5 Prologue Connection Problems
23-11-2008 7:15 PM
My router is a Netgear DG834G and I have UPnP enabled. I have tried putting my PS3 in to the router's DMZ but it makes no difference.
I don't have problems with any other on-line game - Motorstorm for example works fine.
Any ideas?
Thanks - Bob
Re: PS3 GT5 Prologue Connection Problems
23-11-2008 8:22 PM
After some further on-line searching, I followed some advice and changed the UPnP mode from mode 1 to mode 2 (this is under Options > Miscellaneous > Network in the GT5 menu). I then managed to connect to 2 consecutive races but then I was back to being disconnected all the time.
Back to the drawing board ...
Bob
23-11-2008 10:52 PM
Its been a long while since I played this online, can't recall having issues when I have played online but I'll get it out again. I've got a Motorstorm Pacific Rift league qualifier session tomorrow night so might not be till Tuesday before I can try it out.
24-11-2008 7:59 AM
It's been working fine this morning (between 07:00 and 08:00).
Bob
24-11-2008 10:12 AM
Not sure if this will help but found this articale about online play for GT5 Prologue
http://uk.playstation.com/games-media/news/articles/detail/item98146/GT5-Prologue-online-help/
The port mentioned is defined as PlayStation AMS
24-11-2008 6:43 PM
Yes I'd seen that article on the PlayStation web site. I have to admit that I don't really understand all this "port" stuff. I haven't explicitly set up a pot forwarding rule for port 3658 but it's defined on the UPnP screen in my router (see attached). Also I've tried putting my PS3 in the router's DMZ (which I believe effectively opens all ports to all traffic) and that made no difference.
There doesn't seem to be a widespread problem with GT5 on-line or I assume it would be all over the net. That's why I was wondering if it might be a PlusNet problem.
Bob
25-11-2008 11:34 AM
Quote from: _CN_ Hi,
I'll take a look tonight and get back ...
25-11-2008 9:58 PM
I've had two tries this evening. The first at 18:00 I managed to connect to every race, the second at 21:00 I was getting "disconnected from the host" messages on about 50% of my attempts.
There seems to be a pattern of problems in the late evening - presumably when things get busy.
Bob
25-11-2008 11:31 PM
http://en.wikipedia.org/wiki/Gran_Turismo_5_Prologue
<start>
Updates
August 2008 (2.20)
18. Added port 5658 to the ports used in Online races
<end>
I'll get this sorted later on as a packet capture while playing at home shows that indeed 5658 is the port in use.
26-11-2008 8:19 AM
Would you mind explaining in a bit more detail what the fix is. I don't understand why it worked sometimes and sometimes not.
Bob
26-11-2008 9:45 AM
26-11-2008 10:14 AM
Thanks for your help - more great support from PlusNet
Bob
26-11-2008 9:45 PM
Thanks again for your help.
Bob
27-11-2008 8:27 AM
I'll try again tonight.
Bob
03-12-2008 8:24 PM
I've been playing on and off since my last post and have had no connection problems at all.
Looks like problem solved.
Bob
