PCIE cards?
- Gaming
- Re: PCIE cards?
PCIE cards?
15-11-2007 8:28 PM
Always used ATI but recently upgraded the system and am using onboard nVidia. Only buy one game, MotoGP, it is stuggling to play 03, there are so many cards I have no idea what would be required, any suggestions.
thanks
Re: PCIE cards?
18-11-2007 10:22 PM
The more you spend the better!
Got the 8800GTS and its a beauty not found a game yet that kills it... well Crysis on Highest settings, but COD4 runs a treat with everything on full.
Re: PCIE cards?
18-11-2007 10:46 PM
cheers
Re: PCIE cards?
18-11-2007 11:15 PM
Re: PCIE cards?
18-11-2007 11:24 PM
Personally I will be going for the 512MB option and I won't be using XFX who tend to use cheap components
Re: PCIE cards?
18-11-2007 11:32 PM
Re: PCIE cards?
04-12-2007 1:07 PM
I've not been disappointed so far.
Re: PCIE cards?
04-12-2007 2:55 PM
I reckon you only really need the GTX if you're playing in very large resolutions on a widescreen monitor, and as I use a 17" tft this isn't a problem for me.
</2p>
Re: PCIE cards?
05-12-2007 11:14 AM
