PC gaming monitors - any recommendations?
jaread83
Fixes: 81
Hey all,
I am looking to replace my ancient 22" 4:3 Samsung monitor as I have had it for 12 years now and it's time for an upgrade. I have recently noticed that its actually a terrible screen for gaming and is not at all responsive. Can anyone recommend a monitor in the £200 - £300 range? Not bothered with 4K but HD would be nice. Also a low response time and high refresh rate (hoping for 144hz). Looking forward to playing Elite in full HD widescreeen without any ghosting happening. These are the ones I have found that look like they would fit the bill but I just have no idea what to go for:
Asus VG248QE 24-inch 3D LED Monitor - Black (1920x1080, 80000000:1, 144 Hz, 1ms, DVI Display Port, H...
BenQ XL2430T LED 24 inch Gaming Monitor (144 Hz, 16:9, 1920 x 1080, 1000:1, 12M:1, DVI/HDMI 1.4 x 2/...
Cheers!
20 REPLIES 20
Chris
Legend
Fixes: 169
Re: PC gaming monitors - any recommendations?
I bought this a few months ago and would recommend it, the initial setup can take some time getting the brightness/digital vibrance set but after that it's been fantastic : https://www.overclockers.co.uk/acer-predator-gn246hlbbid-24-1920x1080-tn-144hz-1ms-gaming-widescreen...
Oldjim
Fixes: 63
I bought one of these last year and I am delighted with it http://www.iiyama.com/gb_en/products/prolite-xub2790hs-1/
Note that you really should have a full IPS screen
jaread83
Fixes: 81
Those are both nice looking monitors and the specs look on point @Chris for what I need (defo want 144 hz). This going to take a bit of time to decide as its a lot of money to put down (according to the wife).
rongtw
Fixes: 12
I had this before my ROG asus , excellent monitor https://www.overclockers.co.uk/iiyama-g-master-gb2488hsu-b2-24-1920x1080-tn-144hz-freesync-1ms-wides...
jaread83
Fixes: 81
I do like the look of the Asus screens.
I ended up putting up a bit more cash and settled on an Asus MG248Q 24-Inch Widescreen TN LED Full HD Monitor (1920 x 1080, 1 ms, DP, HDMI, DVI-D, 144 MHz). I found this article quite helpful in my decision.
Should be arriving sometime next week!
rongtw
Fixes: 12
Excellent choice Thumbs_Up
i have the Asus rog swift PG278Q  27"
For what its worth Amazon are having a promotion on Asus monitors that give you coupon for a free copy of Doom.
jaread83
Fixes: 81
I saw that but I already have DOOM. Got it on the day of release and I have to say that its probably one of the best single player experiences I have had in recent years. I might have to gift the code to one of my brothers or mates at the next LAN party I go to.
Chris
Legend
Fixes: 169
Or sell it for a low low cost to me.....
St3
Aspiring Champion
Fixes: 5
i could do with a new montior but if i spend anymore pennys on this pc my wife will go bonkers Smiley
jaread83
Fixes: 81
I know what you me @St3, it has taken me a few months to convince my wife that I need a new screen.
Now that I got my new screen... wow... just... wow... games feel completely different and Elite on 3 screens looks amazing!
jaread83
Fixes: 81
Also here is a video I made showing the difference between my old screen (16ms response time) vs my new screen (1ms response time). Captured using my iPhone 'slow-mo' video with high fps so you can see the difference.. I was shocked at how much difference there is.
St3
Aspiring Champion
Fixes: 5
well my current monitor is 5ms, it works very well too and its around 5 years old. But theres lots of nice new things id love to have.... maybe if i take out the fuse i can blag to the wife that the monitor is broke .... just hope she aint reading my posts lol
David_W
I would (strongly) recommend not getting a 1080 monitor, get a 2560x1440 (I use a Benq GW2765), the reason is simple, a screenshot here of ED in 1080 on the Benq...
There is a huge difference between 1080 and 1440, you can pick up one used for under £300.  There is also AOC 27inch 1ms 60-75Hz for £201, it's a TN panel which has it's pro/cons and isn't a 144hz.  I play Elite on Ultra 1440 borderless and have no frame rate issues (970GTX)
