PC gaming monitors - any recommendations?
- Gaming
- Re: PC gaming monitors - any recommendations?
30-06-2016 4:29 PM
Hey all,
I am looking to replace my ancient 22" 4:3 Samsung monitor as I have had it for 12 years now and it's time for an upgrade. I have recently noticed that its actually a terrible screen for gaming and is not at all responsive. Can anyone recommend a monitor in the £200 - £300 range? Not bothered with 4K but HD would be nice. Also a low response time and high refresh rate (hoping for 144hz). Looking forward to playing Elite in full HD widescreeen without any ghosting happening. These are the ones I have found that look like they would fit the bill but I just have no idea what to go for:
Cheers!
30-06-2016 4:40 PM
I bought this a few months ago and would recommend it, the initial setup can take some time getting the brightness/digital vibrance set but after that it's been fantastic : https://www.overclockers.co.uk/acer-predator-gn246hlbbid-24-1920x1080-tn-144hz-1ms-gaming-widescreen...
30-06-2016 4:44 PM
I bought one of these last year and I am delighted with it http://www.iiyama.com/gb_en/products/prolite-xub2790hs-1/
Note that you really should have a full IPS screen
30-06-2016 5:01 PM
Those are both nice looking monitors and the specs look on point @Chris for what I need (defo want 144 hz). This going to take a bit of time to decide as its a lot of money to put down (according to the wife).
30-06-2016 5:40 PM
I had this before my ROG asus , excellent monitor https://www.overclockers.co.uk/iiyama-g-master-gb2488hsu-b2-24-1920x1080-tn-144hz-freesync-1ms-wides...
30-06-2016 10:59 PM
I do like the look of the Asus screens.
I ended up putting up a bit more cash and settled on an Asus MG248Q 24-Inch Widescreen TN LED Full HD Monitor (1920 x 1080, 1 ms, DP, HDMI, DVI-D, 144 MHz). I found this article quite helpful in my decision.
Should be arriving sometime next week!
01-07-2016 7:10 AM
Excellent choice :thumbsup:
i have the Asus rog swift PG278Q 27"
02-07-2016 3:56 PM
For what its worth Amazon are having a promotion on Asus monitors that give you coupon for a free copy of Doom.
04-07-2016 9:57 AM
I saw that but I already have DOOM. Got it on the day of release and I have to say that its probably one of the best single player experiences I have had in recent years. I might have to gift the code to one of my brothers or mates at the next LAN party I go to.
04-07-2016 11:27 AM
06-07-2016 5:50 PM
i could do with a new montior but if i spend anymore pennys on this pc my wife will go bonkers
07-07-2016 9:08 AM
I know what you me @St3, it has taken me a few months to convince my wife that I need a new screen.
Now that I got my new screen... wow... just... wow... games feel completely different and Elite on 3 screens looks amazing!
07-07-2016 9:24 AM
Also here is a video I made showing the difference between my old screen (16ms response time) vs my new screen (1ms response time). Captured using my iPhone 'slow-mo' video with high fps so you can see the difference.. I was shocked at how much difference there is.
11-07-2016 12:21 AM
well my current monitor is 5ms, it works very well too and its around 5 years old. But theres lots of nice new things id love to have.... maybe if i take out the fuse i can blag to the wife that the monitor is broke .... just hope she aint reading my posts lol
13-07-2016 4:47 PM
I would (strongly) recommend not getting a 1080 monitor, get a 2560x1440 (I use a Benq GW2765), the reason is simple, a screenshot here of ED in 1080 on the Benq...
There is a huge difference between 1080 and 1440, you can pick up one used for under £300. There is also AOC 27inch 1ms 60-75Hz for £201, it's a TN panel which has it's pro/cons and isn't a 144hz. I play Elite on Ultra 1440 borderless and have no frame rate issues (970GTX)
