Operation Flashpoint: Dragon Rising
- Gaming
- Operation Flashpoint: Dragon Rising
08-10-2009 3:41 PM
Looks very good, more tactical then CoD or Battlefield?
Re: Operation Flashpoint: Dragon Rising
08-10-2009 4:19 PM
I'll let you know what I think of it after the weekend.
08-10-2009 5:42 PM
games are always better on the pc
it does look good but im the same as you £40 still alot of money waiting on reviews
08-10-2009 8:29 PM
09-10-2009 3:01 PM
09-10-2009 3:09 PM
10-10-2009 4:18 PM
like the tatical multiplayer. very mono colour thoe but battlefield is like that so am use to it. lots of ways to do stuff its jus remembering which buttons press to make it happen
any one fancy a game am running on a diff xbl tag at the moment. Tag= ii hobolow ii
EDIT= well since the first few online games its bein murder to get a match. most the time the server browser returns nothing and most the time cant connect to host. i have found thoe that wen it says trying to connect to host if you click select straight away this dissappers and more than likely you end up connecting.
dam P2P
this is where the ps3'er butt in and say the free network is working ok
13-10-2009 12:04 PM
Loving the single player, took me passing the 2nd mission to really get going but once i did i was off, did a 7 hour stint yesterday. Dont know if i fancy playing online much, you cant be killed by 1 bullet from 200yds away so it could be VERY frustrating!
Prob trade it an after finishing single player, but really like it.
13-10-2009 1:19 PM
I don't like the sound of 4x4 all the time sometimes you just need a 12x12 server just for a good tear up.
13-10-2009 2:19 PM
played anilation (death match) all last nite and had some good fun.
you realy do need to talk to your team thoe and tends to work best if each person has control of a AI sqaud instead of all going in as the same sqaud that way you can realy pin the suckers down in one spot if you keep your AI sqauds in perfect control.
the only thing that anoys me bout the multiplayer is if sum one has control of the AI sqaud your in but dosent even order them to the front line and just leaves them stood at the start point.
Quote you cant be killed by 1 bullet from 200yds away so it could be VERY frustrating!
try a head shot that does the trick in one shot in multiplayer. mind i did get the bug the on sat where you can just keep on shoting sum one and they dont die
14-10-2009 10:49 AM
Quote mind i did get the bug the on sat where you can just keep on shoting sum one and they dont die
They call that the missing bug
Does the AI follow you into the mplayer matches? Its getting a bit more interesting if it does.
14-10-2009 10:57 AM
Quote Does the AI follow you into the mplayer matches?
how do you mean? i havent played the single player yet. i dont tend to i just like playing online.
controling the AI in multiplayer is a big must. j
ust does my nut in when sum one joins your squad as commander when youve picked riflemen for the better gun which means they hav control of the the AI and alot of people dont use them at all or not to there best.
if that happens respawn as a sniper an head for the hills out the way of the kill fest that all ways happens if the other team are using there AI
14-10-2009 8:21 PM
15-10-2009 10:03 AM
edited price my mistake
27-10-2009 1:37 PM
The game can only be described as a simulator as oppose a FPS more in the Ghost Recon Genre, you need to play this for a while to realise that a lot of what you might think are bugs are all intentional in the interests of realism. None of that quick swapping of kit if you decide to put a rifle away in favour of a pistol it takes time.
So far the online experiance has not been good, even when my connection is ok in other games I rarely get one bar in the server & the meter in the lobby has never showed a decent connection to anyone
I will play this game a bit longer and hope that a couple of decent sized patches will improve the game play as the concept of the game is excellant and original. I still prefer the Battlefield series which is sort of midway between, not as complicated as dragon but not as run & shoot as the COD's
I just hope Codemasters get sorted soon with the patches as there bordering on BFBC2 & CODMW2 being released and if the speople who bought this on release or Beta testers as codemaster knows us
