Opening ports?
- Gaming
- Opening ports?
- « Previous
- 1
- 2
- Next »
Re: Opening ports?
31-10-2014 1:43 PM
checking the ports that gamemode opens i think it is more for pc games then console games.on xbox i had crazy lag with it enabled but glad it works for pc
Re: Opening ports?
13-11-2014 12:26 PM
Yea, works for PC, but consoles no luck, Both my ps4 and xbox one are strict nat, in games also. This router is a nightmare for this! ive opened ports, setup static ip, put in the dmz etc etc just nothing works. My old netgear router i never had any problems! There must be a way somehow to sort it out? dont reallly want to buy a new router although have been tempted as these problems are just irritating
Re: Opening ports?
01-12-2014 1:46 PM
Just thought id update, i bought a new router a netgear.. all problems solved.. So if anyones having problems with the thomson ones and cant sort them just buy a new router
Re: Opening ports?
02-12-2014 8:55 AM
To all who have portforwarding problems.
If you are having problems with your console (MAINLY), and your have NAT issues,
and you your about it give,
then give up!
If it's a technicolor router, thats where your probelm lies!!!
get another router, chances are you'd not need to enter ANY port foward. Found out this the hard and stressful way as my NEW router from Plusnet is ****ed
Yes you read correctly
MY NEW ROUTER IS ****ED
ARRRRRRHHH
then give up!
ARRRRRRHHH
- « Previous
- 1
- 2
- Next »
