Onlive Is coming to the UK on the 22nd September
- Gaming
- Onlive Is coming to the UK on the 22nd September
- « Previous
- Next »
Re: Onlive Is coming to the UK on the 22nd September
26-09-2011 10:51 AM
26-09-2011 10:53 AM
26-09-2011 10:57 AM
Could you do me a quick favour and check the wireshark please and see if the IP address of the OnLive server starts with 74.85.x.x. As Bob says we've got a fix going in tomorrow, we had a demo version and built our signatures based so just want to check you're seeing the same as we saw.
Plusnet Technology
26-09-2011 11:13 AM
Hope this helps.
26-09-2011 1:12 PM
Plusnet Technology
26-09-2011 4:21 PM
As per my previous posts my better half Is still with Plusnet and I used It successfully on her connection albeit In the daytime and that was on an up-to 8mbps connection.
Quote from: swedelong I would be interested to know if anyone else on PN has used it successfully yet.
26-09-2011 8:55 PM
I also have the 74.85.xxx.xx IP range and been using it well yesterday but not too well tonight.
27-09-2011 6:12 AM
We tried it on our test line in the office and saw that it could use up to 5Mbps of bandwidth (we have a ~10Mbps line) and thus a lot of usage but worked fine for us.
Plusnet Technology
28-09-2011 12:12 PM
I was one of your first FTTP trialist's and benefit from stable 94mbps down and 15mbps up and have just joined Onlive.
However I am too scared to use it for data uage is too high already and a couple of hours a week would kill me.
What package do you think I should migrate to?
05-10-2011 7:56 PM
had my boys on lego batman at 4.30pm and was very impressed with what i saw, tho after the 30 min demo time i swapped um over to lego harry very annoying potter and from word go had blocking of pixels of the video stream every 3 seconds or so, tested this virgin media 30/3 speed and all was normal no reason for it going to pots.
limited couple of mins i had to test at the time gave me the feeling 1. onlive teething problems 2. VM thottled onlive at 5pm ish as from memory it was bang on 5 when the switched games and 10 past 5 when i had a look for them. 3 again a VM thottle but when onlive usage on my connection hit 1gb as my calculations of the time spent on onlive gave a data usage at that level when it went to pots.
wish VM would open up about there shapping rules just like good old plusnet, tho if i had been on PN i think i would of kicked the boys out to play and kepted the 1gb of usage to my self
20-25mins tbb bandwidth monitoring of the boys lego game gave me around 600MB of usage.
07-10-2011 1:50 PM
For example 2Gb in 4 hours results in DL speeds dropping to ridiculous speed unsuitable for streaming any more.... until the 4 hours period is over and you can download at max speed once again.
I just plucked these figures out of the air, and I may be wrong.... but I'm sure I've read something along these lines.
07-10-2011 1:57 PM
I am not sure why you should ask me as i don't have access to your account so don't know what you are presently on.
Quote from: jonnywishbone Hey OldJim.
However the highest usage account from Plusnet is Extra Fibre with 120GB usage - whether that would be available to you I have no idea
The rate limits on that are http://www.plus.net/support/broadband/speed_guide/download_speeds.shtml but you can always use the Pro addon
09-10-2011 7:38 PM
any one run it on a smart tv, ipad etc yet?
- « Previous
- Next »
- Gaming
