Onlive Is coming to the UK on the 22nd September
- Gaming
- Onlive Is coming to the UK on the 22nd September
12-08-2011 6:42 PM
http://onlive.co.uk/
Re: Onlive Is coming to the UK on the 22nd September
12-08-2011 7:39 PM
13-08-2011 9:46 AM
a big pooop i think
14-08-2011 1:44 PM
If I remember right onlive uses about 1.5gb of data per half hour so you could eat your allowance up pretty quick
14-08-2011 2:02 PM
14-08-2011 2:05 PM
14-08-2011 2:19 PM
14-08-2011 2:22 PM
14-08-2011 2:27 PM
Are you sure as that is about 11.1Mbps
Quote from: Steve Seems this could get costly for some, Splinter cell conviction uses around 5GB an hour, The least graphical game you can play uses around 1.5GB data.
14-08-2011 2:45 PM
14-08-2011 2:50 PM
Changed it I see
14-08-2011 2:52 PM
In the USA onlive worked with the ISPs to get the usage separate from their usage allowance so I'm sure they wouldn't have thought of releasing the service here if they didn't have something arranged at least with bt
14-08-2011 2:59 PM
14-08-2011 3:00 PM
14-08-2011 3:02 PM
- Gaming
