Ongoing World of Warcraft issues
Re: Ongoing World of Warcraft issues
Just made a forum account specifically to post about this - my housemate and I are both having the issues described in the OP. Ran a traceroute while the issue was actually happening so hopefully this helps you fix it:
|                                      WinMTR statistics                                   |
|                       Host              -   %  | Sent | Recv | Best | Avrg | Wrst | Last |
|                           dsldevice.lan -    0 |   34 |   34 |    0 |    2 |    6 |    4 |
|                   No response from host -  100 |    6 |    0 |    0 |    0 |    0 |    0 |
|              be3-3102.pcn-ir02.plus.net -    0 |   34 |   34 |   12 |   15 |   27 |   13 |
|                          195.99.125.144 -    0 |   34 |   34 |   12 |   14 |   25 |   16 |
|                          62.172.103.232 -    0 |   34 |   34 |   12 |   14 |   25 |   13 |
|                          195.99.126.137 -    0 |   34 |   34 |   13 |   16 |   25 |   16 |
|                          209.85.249.218 -    0 |   34 |   34 |   15 |   16 |   26 |   15 |
|                           74.125.242.82 -    0 |   34 |   34 |   14 |   17 |   34 |   16 |
|                          209.85.250.185 -    0 |   34 |   34 |   14 |   17 |   26 |   15 |
|                          209.85.253.196 -    0 |   34 |   34 |   19 |   20 |   32 |   20 |
|                            74.125.37.59 -    0 |   34 |   34 |   19 |   24 |   37 |   27 |
|                         108.170.231.225 -    0 |   34 |   34 |   20 |   23 |   33 |   20 |
|  55.65.199.104.bc.googleusercontent.com -    0 |   34 |   34 |   19 |   21 |   36 |   19 |
|________________________________________________|______|______|______|______|______|______|
   WinMTR v0.92 GPL V2 by Appnor MSP - Fully Managed Hosting & Cloud Provider
It's been fine for most of the evening and then suddenly we both tried to go to the same portal and boom, Transfer Aborted: Instance not found Sad
Sadly have to agree, was fine for a while but now back to the same old transfer issues. Sadly its back to mobile data.
Fixes: 9
So, it sounds like the problem is periodic and only shows itself at certain times?  Do any of you have an inkling if roughly at the same time of day when it starts getting problematic?  If it's roughly the same time each day, it might be a congestion issue somewhere out on the internet.
Who now has a static IP?  If you do, has the problem gone away?  Or are you still seeing it?
Kelly Dorset
Broadband Service Manager
@Kelly I was one of the original lot to be popped on to a static IP about a week ago. There have been no issues resembling the original faults since then and my wife and I play and all kinds of times of day (late morning and mid afternoon, early evening to late evening).
As far as my issues are concerned the Static IP workaround has resolved my issue completely. Would still be keen to understand the 'why' and keeeping a close eye on this thread.
Fixes: 9
I'd like to...
*takes a deep breath*
...take the IP off you for a bit and see if the issue comes back.....   Do you think it would be possible?  I don't want to ruin your gaming, but it would be good to demonstrate that the issue is directly related to the IP you've received.
Kelly Dorset
*twitch*
It would be better to do that now rather than when the expansion comes out!
So let's do it and see what happens.
I'll report back tonight or whenever I get a chance to get my next sesh in.
Fixes: 9
Anyone who is seeing the problem, could you hop on to:
http://us-looking-glass.battle.net/
and select your realm and run some tests and send the results back to us?
Kelly Dorset
Fixes: 921
@carljones wrote:
But think they are looking at a common fix rather than giving fixed IP's out. Not sure what though.
Whilst we'd ideally like to get to a fix, in the interim if adding a static IP improves the gameplay then so be it.
I've added one to your account now.
@Xume1, @tonihly@James1o1o@Marilya thanks for posting. I've been testing your lines and as I'm not able to find any issues which may attribute to the issue you're experiencing, I've also applied a static IP to your accounts.
Could you all let us know how your next gaming sesh goes? Smiley
@samwalton glad to hear you've been able to play without any issues. Thumbs_Up
As well as the above I've just applied now, I've added a list onto the internal problem IMT-2283 where a static IP is confirmed to have resolved the problem, I'll update it with the BBEUs shortly.
@mov
*reluctantly removes static IP*
Having problems with dropping your connection for the dynamic one to apply, I think our wholesale system is also reluctant... if you can reboot your router you'll be routing the way you were before we added a static IP.
Weird, was running the test as requested and my router reset. Not sure if I was on a fixed or not it was 57...... now is 212......
Re-running the test now
EDIT oops see why now 🙂
MTR:
Error! Please, try again later.
17/07/2018 10:09:28 UTC
PING:
TRACEROUTE:
PING:
MTR:
TRACEROUTE:
MTR:
17/07/2018 10:10:08 UTC
TRACEROUTE:
PING:
TRACEROUTE:
MTR:
PING:
 Ran the tests twice and got the same results. Will try again
Fixes: 921
Apologies for the couple of drops in your connection @carljones
Ideally it would've only taken one drop, but I added the static IP, then removed it when I read the problem had been fixed then when I read further down the page it's not fixed I re-added it. Note to self, read whole thread first. Smiley
@carljones I just had the exact same thing happen, weird that XD
Thanks for the IP address, sadly the tests fail at every attempt, will try and run the game now.
EDIT - even with the game running, none of the tests work?
I've run the test three times now and I also get this every time, even with the game running:
MTR:
17/07/2018 10:25:15 UTC
TRACEROUTE:
MTR:
TRACEROUTE:
TRACEROUTE:
MTR:
MTR:
17/07/2018 10:25:55 UTC
TRACEROUTE:
I'll see what happens with the static IP though, thanks for that! Cheesy
Fixes: 9
Ah, that's annoying.  Sad
Kelly Dorset
Fixes: 9
Oops!  That apparently was a US version.  Try this link:http://eu-looking-glass.battle.net/
Seems to work better!
Kelly Dorset
