Odd PS3 issue
Fixes: 1,483
Odd PS3 issue
Well it seems everytime i switch my PS3 it screws my OHs wireless connection.
This makes it nigh on impossible for me to play online whilst she is up..
Any ideas as to what might be causing it? It happens when using the either wired or wireless connection or no connection at all.
Very puzzling...
3 REPLIES 3
sophos9
Re: Odd PS3 issue
Change the wireless channel that the PS3 is running on
Fixes: 1,483
Re: Odd PS3 issue
ok i know what the problem is, the wireless controllers are interfering, using the usb cable it all is ok.
but i thought bluetooth and 802.11 worked on different frequencies?
jnwright
Re: Odd PS3 issue
An interesting article on minimizing bluetooth interference shows that it can be difficult getting the two systems to coexist.
