New to plus net gaming via 360 need advice
professorpain
Hi
I have just switched to plusnet mainly for online gaimg, do I need to enable port forwarding to get the best out of my connection to x box live i am on bbyw pro
any help on how to do this if needed would be great
thanks
paul
2 REPLIES 2
Chris
Legend
Fixes: 169
Re: New to plus net gaming via 360 need advice
As long as your router allows UPnP it should be fine without port forwarding.
If you want to make sure then it's worthwhile following the guides here for your particular router model:-
http://www.portforward.com
professorpain
I see, the router I am using was supplied by your selfs and is a d link, I can t remember having to install software so i assume it is plug and play, but I will try and double check
thanks for your help
