NAT strict, MW3 PC (yes again)
- Gaming
- NAT strict, MW3 PC (yes again)
24-11-2011 5:56 PM
P.S. I also have a Thomson TG585 v7 and that suffers from the exact same problems.
Re: NAT strict, MW3 PC (yes again)
24-11-2011 6:21 PM
24-11-2011 7:12 PM
24-11-2011 7:20 PM
25-11-2011 9:48 AM
Have you had UPnP turned off on the Thomson router whilst doing all of this? If not, could you please try it turned off?
26-11-2011 1:01 PM
29-11-2011 7:01 PM
01-12-2011 11:37 AM
01-12-2011 12:13 PM
Depending on your router you can bind the DMZ via the mac address or IP.
I use a Draytek 2080vn but you can do the same with most routers.
Here is an explanation of DMZ from Netgear.
Quote How To Make a DMZ
A router normally stops incoming Internet traffic from getting on your network, unless the traffic is in response to one of your computers or when using port forwarding. But instead of discarding the incoming traffic or using port forwarding, you can send incoming traffic to one computer on your network by establishing a "Default DMZ Server". (DMZ = humorous reference to "Demilitarized Zone".) This avoids you having to figure out what ports an Internet application wants — by throwing all ports open for that computer.
For regular network operation, NETGEAR recommends you do not use a DMZ. A computer with DMZ loses firewall protection, and is exposed to exploits from the Internet. If compromised, your own computer can attack the rest your network. Instead of DMZ, use port forwarding, as described
01-12-2011 12:40 PM
Ex-Broadband Service Manager
09-12-2011 3:41 PM
09-12-2011 3:44 PM
20-12-2011 9:52 AM
