Modern Warfare 3 - Strict NAT
- Gaming
- Modern Warfare 3 - Strict NAT
19-11-2011 6:08 PM
I'm getting the impression that this isn't exactly an original thread, but hopefully someone will be able to help me. I've recently started playing MW3, but my NAT type is almost always shown as 'strict', which seems to cause lag and problems finding games. I managed to solve this for MW3 by opening ports on the router, and by disabling 'extended security' as I saw hinted on this forum.
Anyway, I've tried the instructions, here:
http://community.plus.net/library/uncategorized/increasing-gaming-compatability-with-the-thomson-tg5...
(Adding a 'saveall' at the end as I also saw noted.)
However, this has not helped. I've tried opening the ports up that I believe MW3 uses, but still to no avail. I'm using the Thompson TG585 v8. I have another router, a linksys, that I've used for a while and that always results in my NAT type showing as 'open'. However this other router seems to have other faults and needs a reboot several times a day, which is why I switched back to the Thompson.
Any help would be greatly appreciated.
Aled
Re: Modern Warfare 3 - Strict NAT
19-11-2011 7:58 PM
20-11-2011 4:04 PM
NEED SOME HELP PLEASE
20-11-2011 6:41 PM
20-11-2011 7:04 PM
20-11-2011 8:37 PM
You are now logged into the command line interface of the router.
Copy and paste the following commands into the window.
:connection unbind application=CONE(UDP) port=69
:connection unbind application=CONE(UDP) port=3074
:connection unbind application=CONE(UDP) port=3478-3479
:connection unbind application=CONE(UDP) port=88
Do you put the commands in telnet or in the bar at the top, as this seems to bring up stuff in google can some one please give me a idiot guy for this. might still not working and i dont really get it
21-11-2011 8:46 AM
21-11-2011 11:19 AM
I can do it remotely for you if you're having a problem with that.
Jojo
24-11-2011 6:51 PM
could you possibly doit remotely for me please.
i had it done already, but somehow it has went back to strict - and the router has never been off.
would really appreciate it - and any advice on how to keep it open.
ta very muckle
lindon
dick:quote
25-11-2011 9:14 AM
Welcome to the forums. That's done for you now.
Jojo
25-11-2011 10:01 AM
any idea why it changed back? or how to stop it changing?
thanks again
me.
25-11-2011 10:06 AM
just went onto mw3 andit still says the nat is strict??
any help please
thanks again
25-11-2011 11:46 AM
If you're running torrents then you need to stop them and reboot the router. This will sort it.
Jojo
25-11-2011 3:52 PM
25-11-2011 4:06 PM
http://community.plus.net/library/gaming/increasing-gaming-compatability-with-the-thomson-tg585v8-xb...
