MW3 PS3 lag issues since switching to PN Fibre but only after midnight
- Gaming
- MW3 PS3 lag issues since switching to PN Fibre but...
Re: MW3 PS3 lag issues since switching to PN Fibre but only after midnight
03-09-2013 3:52 PM
03-09-2013 4:53 PM
Ex-Broadband Service Manager
03-09-2013 5:17 PM
A guide on this can be found here.
You'd need to enter some telnet commands prior to the capture so we get the traffic from the PS3;
Plug the PS3 in port 2 and your PC in port 3
Telnet to the router and log in, details will normally be the following unless you've changed them:
telnet 192.168.1.254
u/n admin
p/w serial number of the router found on the bottom
enter the following commands:
:eth switch mirror capture port 3
:eth switch mirror ingress port 2 state enabled
:eth switch mirror egress port 2 state enabled
If you then start Wireshark it should capture from the PS3.
If you want to leave this permanently set up then you can run the command
saveall
03-09-2013 8:51 PM
04-09-2013 1:00 PM
04-09-2013 4:45 PM
Plusnet Technology
06-09-2013 9:03 AM
Although this may seem weird, I suspect this was caused by me plugging another PC into a switch by the PS3 yesterday afternoon. I think that me plugging/unplugging cables has somehow caused the router to become "confused" with its IP address allocation.
On a positive note, after speaking with a PN rep who told me to forward ports to my PS3 it appears the main lag issue may have gone.
I am concerned though as I have 3 PS3's in the house (the other 2 belong to my sons). I have selfishly forwarded the ports to MY PS3. They don't tend to play late at night, but they do play during the day at weekends and have also complained of lag! Any solutions for this?
06-09-2013 9:28 AM
06-09-2013 9:40 AM
1. Ports needed to be forwarded on the router.
2. The router last night assigned the wrong IP address to the PS3 last night, and hence ports were not being forwarded to it.
This still does not resolve the issue for all PS3's in the house though! I suspect that the other two will be displaying strict NAT types and experieencing lag when my boys play at the weekend. We shall evaluate over the next few days and report back any findings.
Also, I cannot see any IP addresses to ping or tracert from the wireshark output.
06-09-2013 10:06 AM
I have the Thomson 587v7 router and have found it to be very temperamental to use, with it often forgetting settings you have just changed or just randomly rebooting whilst altering settings before they are even complete. When fibre comes shortly i'm going to invest in a better router as i have no confidence in the ones Plusnet distribute.
06-09-2013 10:23 AM
I am toying with the idea of buying a Netgear R6300. Trouble is that it's over £150 and I suspect that if I then experience any issues, the PN will blame the router setup and will not support me in finding a solution!
I have over 20 devices in my house that connect to the router (not all of them at once of course) and I think that this cheap-looking one supplied by PN is struggling to cope. I was also told on the phone that most branded routers have many ports open ready for things such as gaming, whereas the one supplied has the majority of ports closed as it's apparently only really designed for basic users who want to check emails and browse the web??!! I don't know if I was just being fobbed-off or what, but find it slightly antiquated having to use telnet to program it!! I'd never even heard of telnet until a couple of weeks ago!!
07-09-2013 2:28 AM
No change to any settings where I thought the issue had disappeared. All IP's assigned correctly. Just plain lag AGAIN!!
BTW I now have a wireshark capture of this...what do you want me to do with it?? I cannot see any IP addresses to tracert.
07-09-2013 2:32 AM
07-09-2013 2:46 AM
09-09-2013 11:22 AM
As you've got 20 devices connected to your router it's certainly worth disconnecting all of the devices and then try the ones where you've been experiencing issues with on their own.
EDIT - I'd also suggest turning off the port forwarding on the PS3's as they could be conflicting each other and see if this makes a difference.
- Gaming
