MW3 Cannon Fodder
- Gaming
- MW3 Cannon Fodder
MW3 Cannon Fodder
13-12-2011 8:35 PM
I have a feeling its my upload speed which is only 250 or so .... I used to get 500-600 with sky
can PN increase my upload speed for gaming .... not that bothered about browsing
is that possible ?
jim:red all caps removed from title as per forum rules mod:end
Re: MW3 Cannon Fodder
13-12-2011 8:39 PM
Regarding gaming - have you asked for interleaving to be turned off
13-12-2011 9:15 PM
thanks for your reply , my exchange is 21cn enabled . Do I ask PN to uncap my upload or the exchange ?
my interleaving is already OFF
Cheers
13-12-2011 10:33 PM
14-12-2011 2:24 PM
I've just placed the order for you to uncap the upstream, should complete for you tomorrow - hope it helps.
14-12-2011 3:37 PM
Please excuse my ignorance, would turning 'interleaving' off improve my gaming experience too?
Are there any disadvantages to turning it off?
Mark
14-12-2011 5:11 PM
If your line runs at a lower speed and there's errors then interleaving will definitely improve the gaming and lower ping times. If it runs well and at a decent speed though you'll probably get slightly lower pings without it.
If you post some router stats we'll be able to advise better
14-12-2011 8:31 PM
Never able to join games with <100ms ping
14-12-2011 8:33 PM
And give you a bit better speed as well - I assume that your exchange isn't 21CN enabled otherwise you should be on ADSL2+ with much higher speeds
15-12-2011 7:50 AM
15-12-2011 9:51 AM
15-12-2011 5:12 PM
I've placed the order for you to turn it off, should complete tomorrow morning
16-12-2011 6:36 PM
with the flick of a switch you turned me from cannon fodder to johnny RAMBO ....
if anybody wants to go to war message me XBOL BL4CK OPS V3TRN
Thanks Matt much appreciated
16-12-2011 7:59 PM
So play on dedicated servers if the game allows and ignore self hosted servers.
