MAC and NAT Setting
tedglen2
MAC and NAT Setting
Hello I have just spent 20 mins in a que to plusnet, all to be told that they can not help me solve my strict nat settings on xbox.
I found these instructions on the internet …
GO TO ULTILITES > TERMANAL
type telnet 192.168.1.254 and click OK.
USERNAME – admin
PASSWORD – >>>>>>>>
:connection bind application=CONE(UDP) port=69
:connection bind application=CONE(UDP) port=3074
:connection bind application=CONE(UDP) port=3478-3479
:connection bind application=CONE(UDP) port=88
I am using a MAC. This seems to work, but as soon as I close the terminal application on computer, nat goes back to strict. Or if I reset router.
Can someone help ?
2 REPLIES 2
RPMozley
Fixes: 9
Re: MAC and NAT Setting
I believe a save command is required before the end of the telnet session. I'm not sure of the exact wording of it as I don't have the PN supplied router.
I'm sure someone will come along soon with the right settings for you.
That's RPM to you!!
Kelly
Fixes: 9
http://community.plus.net/library/gaming/increasing-gaming-compatability-with-the-thomson-tg585v8-xb...
saveall
Kelly Dorset
Ex-Broadband Service Manager
