Level3 Peering is broken again
- Gaming
- Re: Level3 Peering is broken again
11-02-2014 3:56 AM
Target Name: lb-lsg-prod.ubisoft.comJust look at the peering by Level 3 , London to Paris then to Frankfurt. then AS6453.net Route to Amsterdam back to london before having a go at peering to the USA, and Montreal via a detour Chicago , increase in latency by another 13ms on top off an already ridiculously high ping of 106ms (should be and was 89-95ms ) for several years , and still is lower via other isp's , oh and what's happening re the ongoing latency issue to ubisoft.com, have plusnet forgotten about it? i haven't and haven't heard anything since i was informed that level 3 had been contacted re the dodgy peering
IP: 216.98.48.56
Date/Time: 11/02/2014 02:54:07 to 11/02/2014 03:47:26
Hop Sent Err PL% Min Max Avg Host Name / [IP]
1 1000 176 17.6 0 1 0 home.gateway.home.gateway [192.168.1.254]
2 1000 0 0.0 13 346 20 lo0-central10.pcl-ag02.plus.net [195.166.128.183]
3 1000 0 0.0 13 108 13 link-b-central10.pcl-gw02.plus.net [212.159.2.166]
4 1000 0 0.0 12 48 13 xe-10-1-0.pcl-cr02.plus.net [212.159.0.198]
5 1000 0 0.0 12 66 14 ae2.pcl-cr01.plus.net [195.166.129.6]
6 1000 0 0.0 13 122 16 xe-11-2-0.edge3.London2.Level3.net [212.187.201.213]
7 608 2 0.3 25 40 26 ae-3-3.ebr1.Paris1.Level3.net [4.69.141.86]
8 608 0 0.0 25 38 25 ae-91-91.csw4.Paris1.Level3.net [4.69.161.90]
9 608 0 0.0 25 46 26 ae-92-92.ebr2.Paris1.Level3.net [4.69.161.105]
10 608 0 0.0 25 37 25 ae-46-46.ebr1.Frankfurt1.Level3.net [4.69.143.137]
11 608 3 0.5 25 41 25 ae-71-71.csw2.Frankfurt1.Level3.net [4.69.140.6]
12 608 1 0.2 25 116 26 ae-2-70.edge4.Frankfurt1.Level3.net [4.69.154.72]
13 608 0 0.0 25 85 26 ix-18-0.tcore1.FR0-Frankfurt.as6453.net [195.219.50.49]
14 608 25 4.1 119 176 122 if-9-2.tcore1.FNM-Frankfurt.as6453.net [195.219.50.42]
15 608 17 2.8 120 145 121 if-5-2.tcore1.AV2-Amsterdam.as6453.net [195.219.194.13]
16 608 0 0.0 119 131 119 if-13-2.tcore2.AV2-Amsterdam.as6453.net [80.231.152.22]
17 619 0 0.0 113 137 120 if-8-2.tcore2.L78-London.as6453.net [80.231.131.5]
18 1000 33 3.3 106 176 116 if-20-2.tcore2.NYY-NewYork.as6453.net [216.6.99.13]
19 1000 26 2.6 106 127 114 if-12-6.tcore1.CT8-Chicago.as6453.net [216.6.99.46]
20 1000 73 7.3 106 130 114 if-22-2.tcore2.CT8-Chicago.as6453.net [64.86.79.1]
21 1000 22 2.2 106 187 117 if-3-2.tcore1.W6C-Montreal.as6453.net [66.198.96.45]
22 999 999 100.0 0 0 0 [-]
Destination not reached in 35 hops
Update:
Target Name: lb-lsg-prod.ubisoft.comIt changed to this minutes ago, why all the london hops from level 3? ubisoft should be 12-14 hops not 18+
IP: 216.98.48.56
Date/Time: 11/02/2014 03:27:02 to 11/02/2014 04:19:33
1 1000 178 17.8 0 1 0 home.gateway.home.gateway [192.168.1.254]
2 1000 0 0.0 13 348 19 lo0-central10.pcl-ag02.plus.net [195.166.128.183]
3 1000 0 0.0 12 90 13 link-b-central10.pcl-gw02.plus.net [212.159.2.166]
4 1000 0 0.0 12 59 14 xe-10-1-0.pcl-cr02.plus.net [212.159.0.198]
5 1000 0 0.0 12 89 14 ae2.pcl-cr01.plus.net [195.166.129.6]
6 1000 1 0.1 13 126 16 xe-11-2-0.edge3.London2.Level3.net [212.187.201.213]
7 387 0 0.0 13 77 17 ae-0-11.edge4.London2.Level3.net [4.69.200.126]
8 387 1 0.3 13 25 13 ae-3-3.ebr1.London15.Level3.net [4.69.141.189]
9 387 1 0.3 13 35 13 ae-44-44.ebr1.London1.Level3.net [4.69.167.30]
10 387 1 0.3 13 25 13 ae-58-113.csw1.London1.Level3.net [4.69.153.122]
11 387 11 2.8 13 69 14 ae-116-3502.edge3.London1.Level3.net [4.69.166.134]
12 382 14 3.7 13 73 16 ix-20-0.tcore1.LDN-London.as6453.net [195.219.83.101]
13 382 20 5.2 106 114 106 if-17-2.tcore1.L78-London.as6453.net [80.231.130.129]
14 382 23 6.0 105 117 105 if-2-2.tcore2.L78-London.as6453.net [80.231.131.1]
15 1000 14 1.4 106 198 116 if-20-2.tcore2.NYY-NewYork.as6453.net [216.6.99.13]
16 1000 14 1.4 106 129 114 if-12-6.tcore1.CT8-Chicago.as6453.net [216.6.99.46]
17 1000 56 5.6 106 130 114 if-22-2.tcore2.CT8-Chicago.as6453.net [64.86.79.1]
18 1000 14 1.4 106 194 118 if-3-2.tcore1.W6C-Montreal.as6453.net [66.198.96.45]
11-02-2014 10:49 AM
11-02-2014 11:45 AM
Deathtrap you appear to have packet loss at your first hop? Do you have an explanation for that? WHat ever is going on is causing latency between you and our gateway. (as you can see by the max time on lo0-central10.pcl-ag02.plus.net)
What are you actually doing which isn't working properly? Don't fixate on the number of hops, there are more devices passing your packets along between your router and hop 1 on your trace route than in the entire rest of the trace. It's the end to end performance we need to look at.
Ex-Broadband Service Manager
11-02-2014 11:57 AM
11-02-2014 2:13 PM
The packet loss on the first hop is not new for deathtrap: http://community.plus.net/forum/index.php/topic,118180.msg1023453.html#msg1023453
Probably totally unrelated, but there was an issue recently with BT Retail/Ubisoft. Neil McRae at BT was supposed to explain what the problem was and how it was fixed, but he never did explain it.
11-02-2014 2:16 PM
Deathtrap's line is showing packet loss on first hop, variable latency in traceroutes, and slowdowns at peak. I don't think these are seen by the majority of customers, so it just feels like there is something else wrong here.
11-02-2014 2:17 PM
Quote from: AndyH Probably totally unrelated, but there was an issue recently with BT Retail/Ubisoft. Neil McRae at BT was supposed to explain what the problem was and how it was fixed, but he never did explain it.
I'm going to see if I can find out what happened with that, but I don't think it's related. The problem was causing people to be completely unable to log into uplay, which is quite a distinct, disruptive issue!
11-02-2014 2:46 PM
Tracing route to ubisoft.com [216.98.48.40]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms home.gateway.home.gateway [192.168.1.254]
2 15 ms 14 ms 13 ms lo0-central10.ptw-ag01.plus.net [195.166.128.195]
3 14 ms 14 ms 13 ms link-a-central10.ptw-gw01.plus.net [212.159.2.144]
4 14 ms 14 ms 14 ms xe-4-2-0.ptw-cr01.plus.net [212.159.0.240]
5 14 ms 14 ms 14 ms te-3-4.car5.London1.Level3.net [217.163.45.181]
6 15 ms 15 ms 14 ms ae-52-52.csw2.London1.Level3.net [4.69.139.120]
7 14 ms 14 ms 14 ms ae-225-3601.edge3.London1.Level3.net [4.69.166.146]
8 19 ms 44 ms 30 ms ix-20-0.tcore1.LDN-London.as6453.net [195.219.83.101]
9 117 ms 117 ms 118 ms if-17-2.tcore1.L78-London.as6453.net [80.231.130.129]
10 118 ms 117 ms 118 ms if-2-2.tcore2.L78-London.as6453.net [80.231.131.1]
11 125 ms 129 ms 117 ms if-20-2.tcore2.NYY-NewYork.as6453.net [216.6.99.13]
12 117 ms 116 ms 117 ms if-12-6.tcore1.CT8-Chicago.as6453.net [216.6.99.46]
13 118 ms 117 ms 118 ms if-22-2.tcore2.CT8-Chicago.as6453.net [64.86.79.1]
14 116 ms 130 ms 117 ms if-3-2.tcore1.W6C-Montreal.as6453.net [66.198.96.45]
15 * * * Request timed out.
16 * * * Request timed out.
17 * * * Request timed out.
18 * * * Request timed out.
19 * * * Request timed out.
20 * * * Request timed out.
21 * * * Request timed out.
22 * * * Request timed out.
23 * * * Request timed out.
24 * * * Request timed out.
25 * * * Request timed out.
26 * * * Request timed out.
27 * * * Request timed out.
28 * * * Request timed out.
29 * * * Request timed out.
30 * * * Request timed out.
Trace complete.
11-02-2014 4:39 PM
Target Name: lb-lsg-prod.ubisoft.comRouter wasn't busy this time
IP: 216.98.48.56
Date/Time: 11/02/2014 16:18:37 to 11/02/2014 16:30:31
1 540 0 0.0 0 0 0 home.gateway.home.gateway [192.168.1.254]
2 540 0 0.0 13 359 20 lo0-central10.pcl-ag02.plus.net [195.166.128.183]
3 540 0 0.0 13 187 13 link-b-central10.pcl-gw02.plus.net [212.159.2.166]
4 540 0 0.0 12 85 14 xe-10-1-0.pcl-cr02.plus.net [212.159.0.198]
5 540 0 0.0 12 65 15 ae2.pcl-cr01.plus.net [195.166.129.6]
6 540 0 0.0 13 76 14 xe-11-2-0.edge3.London2.Level3.net [212.187.201.213]
7 540 0 0.0 13 72 15 ae-0-11.edge4.London2.Level3.net [4.69.200.126]
8 540 1 0.2 13 37 13 ae-3-3.ebr1.London15.Level3.net [4.69.141.189]
9 540 0 0.0 13 49 13 ae-43-43.ebr1.London1.Level3.net [4.69.167.26]
10 540 0 0.0 13 25 13 ae-59-114.csw1.London1.Level3.net [4.69.153.126]
11 540 0 0.0 13 79 15 ae-117-3503.edge3.London1.Level3.net [4.69.166.138]
12 540 0 0.0 13 57 14 ix-20-0.tcore1.LDN-London.as6453.net [195.219.83.101]
13 540 5 0.9 106 125 106 if-17-2.tcore1.L78-London.as6453.net [80.231.130.129]
14 540 13 2.4 105 118 105 if-2-2.tcore2.L78-London.as6453.net [80.231.131.1]
15 540 2 0.4 106 146 108 if-20-2.tcore2.NYY-NewYork.as6453.net [216.6.99.13]
16 540 0 0.0 106 118 106 if-12-6.tcore1.CT8-Chicago.as6453.net [216.6.99.46]
17 540 21 3.9 106 115 106 if-22-2.tcore2.CT8-Chicago.as6453.net [64.86.79.1]
18 540 0 0.0 106 174 109 if-3-2.tcore1.W6C-Montreal.as6453.net [66.198.96.45]
Heres a tcp ping
Target Name: lb-lsg-prod.ubisoft.comone of many routes as it switches back and forth a lot, causing the fluctuation in latency
IP: 216.98.48.56
Date/Time: 11/02/2014 16:18:37 to 11/02/2014 16:38:05
1 892 1 0.1 0 4 0 home.gateway.home.gateway [192.168.1.254]
2 892 0 0.0 13 359 22 lo0-central10.pcl-ag02.plus.net [195.166.128.183]
3 892 0 0.0 13 187 13 link-b-central10.pcl-gw02.plus.net [212.159.2.166]
4 892 0 0.0 12 85 14 xe-10-1-0.pcl-cr02.plus.net [212.159.0.198]
5 879 0 0.0 12 65 14 ae2.pcl-cr01.plus.net [195.166.129.6]
6 17 0 0.0 13 14 13 xe-11-1-0.edge3.London2.Level3.net [212.187.201.209]
7 872 4 0.5 13 72 15 ae-0-11.edge4.London2.Level3.net [4.69.200.126]
8 879 2 0.2 13 37 13 ae-3-3.ebr1.London15.Level3.net [4.69.141.189]
9 4 0 0.0 13 13 13 ae-226-3602.edge3.London1.Level3.net [4.69.166.150]
10 16 0 0.0 13 22 14 ae-56-111.csw1.London1.Level3.net [4.69.153.114]
11 15 0 0.0 14 14 14 ae-116-3502.edge3.London1.Level3.net [4.69.166.134]
12 884 0 0.0 13 57 14 ix-20-0.tcore1.LDN-London.as6453.net [195.219.83.101]
13 880 2 0.2 106 149 108 if-20-2.tcore2.NYY-NewYork.as6453.net [216.6.99.13]
14 884 1 0.1 106 160 106 if-12-6.tcore1.CT8-Chicago.as6453.net [216.6.99.46]
15 8 0 0.0 107 129 112 if-20-2.tcore2.NYY-NewYork.as6453.net [216.6.99.13]
16 884 0 0.0 106 174 109 if-3-2.tcore1.W6C-Montreal.as6453.net [66.198.96.45]
17 16 0 0.0 107 112 108 if-22-2.tcore2.CT8-Chicago.as6453.net [64.86.79.1]
18 8 0 0.0 107 122 111 if-3-2.tcore1.W6C-Montreal.as6453.net [66.198.96.45]
19 28 0 0.0 107 144 111 [66.198.96.18]
20 887 855 96.4 107 121 111 lb-lsg-prod.ubisoft.com [216.98.48.56]
Target Name: lb-lsg-prod.ubisoft.comdoesn't route via Chicago, so correctly routed i believe this could be the issue it shouldn't use the Chicago route at all
IP: 216.98.48.56
Date/Time: 11/02/2014 16:19:52 to 11/02/2014 16:40:50
1 1000 1 0.1 0 4 0 home.gateway.home.gateway [192.168.1.254]
2 1000 0 0.0 13 359 22 lo0-central10.pcl-ag02.plus.net [195.166.128.183]
3 1000 0 0.0 13 187 13 link-b-central10.pcl-gw02.plus.net [212.159.2.166]
4 1000 0 0.0 12 85 14 xe-10-1-0.pcl-cr02.plus.net [212.159.0.198]
5 963 0 0.0 12 65 14 ae2.pcl-cr01.plus.net [195.166.129.6]
6 846 0 0.0 13 76 14 xe-11-2-0.edge3.London2.Level3.net [212.187.201.213]
7 948 14 1.5 13 72 15 ae-0-11.edge4.London2.Level3.net [4.69.200.126]
8 962 2 0.2 13 37 13 ae-3-3.ebr1.London15.Level3.net [4.69.141.189]
9 58 0 0.0 13 14 13 ae-42-42.ebr1.London1.Level3.net [4.69.167.22]
10 829 0 0.0 13 25 13 ae-59-114.csw1.London1.Level3.net [4.69.153.126]
11 41 0 0.0 13 56 16 ae-115-3501.edge3.London1.Level3.net [4.69.166.130]
12 928 1 0.1 13 57 15 ix-20-0.tcore1.LDN-London.as6453.net [195.219.83.101]
13 939 13 1.4 106 137 106 if-17-2.tcore1.L78-London.as6453.net [80.231.130.129]
14 85 1 1.2 105 116 105 if-2-2.tcore2.L78-London.as6453.net [80.231.131.1]
15 928 8 0.9 106 149 108 if-20-2.tcore2.NYY-NewYork.as6453.net [216.6.99.13]
16 940 1 0.1 106 174 109 if-3-2.tcore1.W6C-Montreal.as6453.net [66.198.96.45]
17 170 1 0.6 107 216 111 [66.198.96.18]
18 162 2 1.2 106 121 107 msr-onl-fw01.ubisoft.com [216.98.51.10]
19 992 813 82.0 106 174 112 lb-lsg-prod.ubisoft.com [216.98.48.56]
But lets not loose sight on what the original problem was the increase in latency from 89-95ms to what i have today, it shouldn't be this high have plusnet complained to level 3 or asked them to contact AS6453.net and ask them why traffic is being routed away from Montreal from NewYork or asked if they can provide a shorter route with lower latency ? as far as i can nothing much has or is being done
As for what is causing the spikes in latency between the router and your gateway , better ask BT wholesale about that or check the gateway, as it's nothing this side causing the spiking , but it's nothing new
11-02-2014 5:20 PM
Some of those hops will be set to low priority ICMP - I can ping bbc.co.uk and get 4-5 ms over 1000 pings, but if I ping my PN gateway I get anything ranging from 5-300ms.
11-02-2014 5:36 PM
11-02-2014 5:54 PM
11-02-2014 6:03 PM
Quote from: deathtrap What appears to be packet loss isn't it's because the router is busy, and like some switches on the internet doesn't respond to every icmp request, as to how is this affecting me, well mm, lagggg, for me if i join someone's game or they experience it when i'm hosting the game, due to the degree of fluctuation of the base latency at times , all those hops can only make that worse , regardless of if they are adding latency or not
Which games? Are other PN players seeing the same problems, or is it just your line.
What are you doing to keep your router that busy? Does the lag disappear if you are only gaming?
11-02-2014 7:01 PM
so are probably being run close to or at capacity ,not good for on-line gaming or even voice coms The lag is only a problem when gaming, what was i doing to keep my router that busy, nothing much apart from pinging some other destinations using pingplotter pro
11-02-2014 7:06 PM
