Left 4 Dead Problems.
Dorian182
My left 4 dead has been running without lag since I started with Plusnet, but now I never have a ping lower than 100 and it lags, If I try and make a server I disconnect around a minute after it loads, Its not doing this with any of my other steam games. Does anyone have any Idead how I can solve this problem?
No Firewall running apart from windows firewall and yes I have tried turning it off.
I have reinstalled it (L4D).
I am on plusnet Pro.
Help would be much appreciated as I play this game alot.
1 REPLY 1
Re: Left 4 Dead Problems.
Hi Dorian,
Have you tried running a traceroute to any of the servers you go on? This could show you where any slow hops are and give you an idea what may be causing the issue.
If that doesn't show anything up you could try a wireshark capture when you're playing L4D - there's details on using wireshark at http://www.plus.net/support/broadband/troubleshooting/wireshark.shtml
Hope that helps,
