Left 4 Dead / 2 - Prioritised gaming??
- Gaming
- Re: Left 4 Dead / 2 - Prioritised gaming??
31-12-2009 12:20 PM
Other games at this time are fine, just these two affected
Although i have Wireshark install ihavent a clue how to use it so can't test that.
31-12-2009 2:27 PM
31-12-2009 2:40 PM
02-01-2010 5:51 PM
04-01-2010 10:04 AM
Now leave wireshark running and start the game. After a few minutes quit the game, then click the "Stop the running live capture" button. Save the file (should have the extension .pcap) then attach it to a ticket in our contact us section.
HTH.
04-01-2010 12:53 PM
on l4d2 you can select to use your own host in permissions but I'm sure its US servers only which explains the problem if you have dedicated
04-01-2010 1:53 PM
04-01-2010 8:32 PM
28-05-2010 1:01 PM
28-05-2010 5:22 PM
28-08-2010 1:57 PM
When I'm in the game however the ping is <50ms, so it's something else causing it. I've tried almost everything I can like removing firewalls, changing settings etc but nothing.
Is this still been looked into?
08-09-2010 2:15 PM
Edit: The rollout is ready to go but doesn't have a rollout slot yet. Please keep your eye on this thread which will be updated as soon as the change is applied.
