Latency issues whilst Gaming (Path Of Exile)
- Gaming
- Latency issues whilst Gaming (Path Of Exile)
Re: Latency issues whilst Gaming (Path Of Exile)
20-07-2018 6:00 PM - edited 20-07-2018 6:11 PM
@OldGamer That's great news.
You are still on a static IP though, meaning you are skipping the piece of kit we think we've fixed. Are you around for the next 30 mins and willing to test if it works without it?
Edit: Don't worry, I'll look at this next week!
Ex-Plusnet Jobsbody
20-07-2018 7:03 PM
Hi Kelly,
Sorry - had logged off for Friday night takeaway! If you can tell me how to get back to a dynamic IP address though I'd be happy to re-test.
OldGamer.
20-07-2018 11:23 PM
Hi getting the same issue here, without VPN:
| Host - % | Sent | Recv | Best | Avrg | Wrst | Last |
| dsldevice.lan - 0 | 102 | 102 | 0 | 1 | 2 | 1 |
| No response from host - 100 | 102 | 0 | 0 | 0 | 0 | 0 |
| 195.166.143.133 - 90 | 102 | 11 | 12 | 12 | 12 | 12 |
| be3-3102.pcn-ir02.plus.net - 0 | 101 | 101 | 13 | 13 | 16 | 13 |
| 195.99.125.144 - 0 | 101 | 101 | 11 | 12 | 13 | 12 |
| peer2-et-0-0-4.slough.ukcore.bt.net - 0 | 101 | 101 | 14 | 14 | 28 | 14 |
| No response from host - 100 | 101 | 0 | 0 | 0 | 0 | 0 |
| po96.net2.north.dc5.as20860.net - 0 | 101 | 101 | 13 | 18 | 81 | 14 |
| 1718.g2.1ug.dc5.as20860.net - 0 | 101 | 101 | 14 | 17 | 103 | 14 |
| 87.117.210.61 - 3 | 101 | 98 | 14 | 17 | 62 | 15 |
| 109.169.19.133 - 0 | 101 | 101 | 14 | 14 | 16 | 15 |
|________________________________________________|______|______|______|______|______|______|
Gameplay freezes often, being oro's flicker its just aweful. However with VPN game play was flawless, spike rarely, ping is generally flat, gameplay stable:
| 46.101.72.156 - 0 | 108 | 108 | 12 | 13 | 45 | 12 |
| 46.101.72.253 - 0 | 108 | 108 | 12 | 15 | 41 | 20 |
| 138.197.249.248 - 0 | 108 | 108 | 12 | 17 | 57 | 13 |
| be20.asr01.ld5.as20860.net - 0 | 107 | 107 | 13 | 16 | 58 | 14 |
| po96.net2.north.dc5.as20860.net - 0 | 107 | 107 | 13 | 18 | 73 | 15 |
| 1718.g2.1ug.dc5.as20860.net - 1 | 107 | 106 | 13 | 16 | 81 | 14 |
| 87.117.210.61 - 3 | 107 | 104 | 14 | 18 | 70 | 14 |
| 109.169.19.133 - 0 | 107 | 107 | 13 | 16 | 61 | 14 |
I'm available for testing if needed.
21-07-2018 8:10 PM
Hey @OldGamer
About to log off now for the night, but if you're around tomorrow and fancy testing I'll be able to put you back onto a dynamic IP at around 10 am tomorrow morning?
21-07-2018 10:42 PM
Hi Gandalf,
That will be fine - I'll test it after 10am tomorrow (Sunday) without using the VPN client and will let you know.
OldGamer
22-07-2018 9:38 AM
Cheers @OldGamer I've destroyed the static IP now, let us know how your gaming goes without a VPN.
Though it looks like people over on the WoW thread are still having issues with a dynamic IP but would be interesting to know from a PoE perspective.
22-07-2018 10:13 AM
Hi Gandalf,
Re-tested without the VPN client (and following the change back to dynamic IP address) and unfortunately the lag and freezing were straight back, WinMTR test results below:-
Host % Sent Recv Best Avrg Wrst Last
dsldevice.lan 0 672 672 0 0 3 0
No response from host 100 134 0 0 0 0 0
be3-3102.pcn-ir02.plus.net 0 672 672 10 11 31 11
195.99.125.144 1 668 667 10 11 47 11
peer2-et3-1-4.slough.ukcore.bt.net 0 672 672 11 12 35 12
po96.net2.north.dc5.as20860.net 0 672 672 12 16 201 13
1718.g2.1ug.dc5.as20860.net 1 665 663 12 13 117 12
87.117.210.61 2 633 623 11 14 106 12
109.169.19.133 0 672 672 11 11 29 11
Kind regards,
OldGamer.
22-07-2018 8:04 PM
22-07-2018 8:24 PM
Hi Gandalf,
I wasn't on a static IP address before (unless someone put one on my account for testing) - it's not something I'd bought from Plusnet previously. No worries though - everything is playing fine through the VPN client thanks. Enjoy your day off. 🙂
OldGamer.
22-07-2018 8:53 PM - edited 22-07-2018 8:53 PM
Hey OldGamer
Reading through the thread again it looks like I didn't explicitly say I added a static IP, but the change I made to your connection was essentially done by adding one.
That's a relief!
I'll try. Got to clean the house and tidy my room...
22-07-2018 10:32 PM
I'm having the same issues regarding Path of Exile described by others. My winMTR looks like this:
|------------------------------------------------------------------------------------------| | WinMTR statistics | | Host - % | Sent | Recv | Best | Avrg | Wrst | Last | |------------------------------------------------|------|------|------|------|------|------| | dsldevice.lan - 0 | 1785 | 1785 | 3 | 4 | 15 | 4 | | Request timed out. - 100 | 359 | 0 | 0 | 0 | 0 | 0 | | 129.hiper04.sheff.dial.plus.net.uk - 100 | 360 | 2 | 0 | 13 | 14 | 13 | | be3-3100.pcn-ir01.plus.net - 1 | 1762 | 1756 | 12 | 13 | 38 | 13 | | 195.99.125.136 - 1 | 1774 | 1771 | 12 | 13 | 47 | 14 | | peer2-et3-1-4.slough.ukcore.bt.net - 0 | 1784 | 1784 | 11 | 14 | 41 | 13 | | Request timed out. - 100 | 359 | 0 | 0 | 0 | 0 | 0 | | po96.net2.north.dc5.as20860.net - 1 | 1781 | 1780 | 12 | 18 | 271 | 13 | | 1718.g2.1ug.dc5.as20860.net - 1 | 1758 | 1751 | 14 | 16 | 121 | 16 | | 87.117.210.61 - 3 | 1626 | 1584 | 13 | 17 | 133 | 19 | | 109.169.19.133 - 0 | 1784 | 1784 | 13 | 14 | 34 | 14 | |________________________________________________|______|______|______|______|______|______| WinMTR v1.00 GPLv2 (original by Appnor MSP - Fully Managed Hosting & Cloud Provider)
23-07-2018 10:13 AM - edited 23-07-2018 10:19 AM
Hi @exxxie and welcome to the forums, I'm sorry you're having issues.
I've added a static IP to your account please turn your router off for a few minutes and reconnect and let us know how you're getting on.
23-07-2018 9:08 PM
The situation seems much better now. Stable ping and very little packet loss at 8:30pm is a marked improvement over recent weeks. Thanks JonoH for your prompt help. I've pasted a winMTR below in case it assists you:
|------------------------------------------------------------------------------------------| | WinMTR statistics | | Host - % | Sent | Recv | Best | Avrg | Wrst | Last | |------------------------------------------------|------|------|------|------|------|------| | dsldevice.lan - 0 | 2302 | 2302 | 3 | 4 | 15 | 4 | |410.xe-2-2-0.central10.psb-bng01.plus.net - 0 | 2301 | 2301 | 12 | 12 | 58 | 12 | | 411.be5.psb-ir01.plus.net - 1 | 2252 | 2239 | 12 | 13 | 22 | 13 | | 195.99.125.134 - 1 | 2268 | 2259 | 12 | 13 | 28 | 12 | | peer2-et0-1-5.slough.ukcore.bt.net - 1 | 2242 | 2226 | 13 | 14 | 38 | 13 | | Request timed out. - 100 | 462 | 0 | 0 | 0 | 0 | 0 | | po95.net2.north.dc5.as20860.net - 1 | 2271 | 2263 | 14 | 19 | 271 | 15 | | 1718.g2.1ug.dc5.as20860.net - 1 | 2233 | 2215 | 13 | 15 | 120 | 14 | | 87.117.210.61 - 3 | 2074 | 2015 | 13 | 17 | 136 | 14 | | 109.169.19.133 - 1 | 2290 | 2287 | 14 | 15 | 21 | 15 | |________________________________________________|______|______|______|______|______|______| WinMTR v1.00 GPLv2 (original by Appnor MSP - Fully Managed Hosting & Cloud Provider)
31-07-2018 9:35 AM
Hey Path of Exile players. How has it been for the past week?
Ex-Plusnet Jobsbody
31-07-2018 9:52 AM
I don't know whats been changed but personally I haven't had to use a VPN at all all week, it's been smooth as butter for me. I just hope when my broadband moves to my new place it's still gonna be smooth.
