Lag?
KaotiK
Lag?
Seem to be getting real bad lag spikes in games the past few days. Kinda like loss or choke as itd be a steam game. Anyone else getting the same or any ideas what it would be?
8 REPLIES 8
Euge
Re: Lag?
During any particular time of day? Has anything changed with your setup. Have you considered turning off interleaving if you havn't already?
I have no experience with games from steam but someone else might know more.
There is some program that will monitor your connection for changes in line quality during the course of a day.
Strat
Fixes: 565
Re: Lag?
Quote from: Euge
Router Stats at http://vwlowen.co.uk/internet/files for example.
Euge
Re: Lag?
Thanks Strat  Smiley I knew someone would know of one.
KaotiK
Re: Lag?
Havent changed anything, and its usually in the evening which means prolly throttling maybe? cuz ig et slow web page loading then aswell but thats a diffrent matter. Any time i do speedtests, i do 3 or 4  every few mins and my speeds are so up and down, sometimes 6,5,4,3,2 etc lol
And interleaving was thinking about it but doesnt it make your connection unstable?
James
Re: Lag?
Interleaving will only make your connection unstable if there are errors on your line.
If there aren't, you should be fine.
KaotiK
Re: Lag?
Would it just lower my ping or do anything else? its like right now its taking me a few mins to connect to a ventrilo server :S and ive tried a few diff ones so it cant be the host. Is that throttling or? just weird.
Just to edit: and whats confusing is my speed is damn near 6mb, so i dont get how its taking my years to connect to a ventrilo serevr right now, started around 3, went out came back and its the same now.
goberpiles
Re: Lag?
I have been awful problems on Fifa 09 on the PS3 for the past few days, clubs is unplayable with a 5-6 second delay in controlling my player, I am on unlimited I have unlocked all the required ports and I still have issues.
Anyone any ideas on what I can try and do, its driving me nuts.
KaotiK
Re: Lag?
Just getting spikes then whilst palying, heres router stats for right now.
Port  Status  TxPkts  RxPkts  Collisions  Tx B/s  Rx B/s  Up Time
WAN PPPoA 1643552 2179538 0 2565 33911 14:42:11
LAN 10M/100M 2157139 1631926 0 33963 3149 14:42:42
WLAN 11M/54M 24516 15881 0 517 43 14:42:32
ADSL Link Downstream Upstream
Connection Speed 7616 kbps 448 kbps
Line Attenuation 13 db 3 db
Noise Margin 10 db 26 db
I mean it could just be a certain server i connect to that plusnet dont agree with, dunno, cuz it doesnt happen on every server i dont reckon.
Are those stats fine or?
