Lag on LoL
thatbeachchick
Re: Lag on LoL
Day 2 with no internet, can I get some help over here please?
Pettitto
Fixes: 5
Re: Lag on LoL
Please follow the steps below to set up your router:
1. Connect an Ethernet Cable to the router and plug the other end into the computer/laptop.
2. Open up your Web Browser (Such as Internet Explorer).
3. In the address bar at the top of the page (where it says http) you will need to delete whatever is in there, and replace this with: 192.168.1.254
4. You will be prompted for a username and password. (These should have been supplied when you received the router)
5. You should now be logged into the Technicolor Gateway. Click where it says 'Technicolor Gateway' (Just once).
6. In the middle of your screen you should see where it says 'Pick a Task', directly underneath that, you should see 'Set up my Technicolor Gateway', please click this.
7. Click, 'Next' >> Make sure Plusnet is highlighted and click 'Next' again.
8. Type in your account username followed by @plusdsl.net and also fill in your account password in the password field.
9. Click 'Next' and then click where it says 'Start'.
10. You should see a screen saying 'Configuring your Technicolor Gateway'. After a few minutes this should complete and you then need to click 'Finish'.
Please let me know if you require any further support.
thatbeachchick
Re: Lag on LoL
Did all that, got to the final step where it was configuring, and then all I get is 'this webpage is not available'. Tried from step 6 onwards and it just keeps coming up with webpage not available.
Kelly
Fixes: 9
Re: Lag on LoL
That doesn't sound good.  Give the router a factory reset and try again?
http://www.plus.net/support/broadband/hardware/technicolor-582n-faqs.shtml#factoryReset
Kelly Dorset
Ex-Broadband Service Manager
thatbeachchick
Re: Lag on LoL
It just keeps doing exactly the same thing 😕
Pettitto
Fixes: 5
Re: Lag on LoL
I'll give you a ring first thing in the morning if you'll be around and have access to your router?
thatbeachchick
Re: Lag on LoL
Yes, thank you.
adamwalker
Fixes: 221
Re: Lag on LoL
Cheers for your time on the phone!
It does very much sound like there could be an issue with your router.
I've updated ticket 76858664 which you should be able to see at http://contactus.plus.net and have arranged a replacement to be dispatched.
Adam
 Adam Walker
thatbeachchick
Re: Lag on LoL
Okay we got the new router and it's doing exactly the same as the other router
chrispurvey
Re: Lag on LoL
@thatbeachchick
I can see you've just connected, is it now working for you?
Kelly
Fixes: 9
Re: Lag on LoL
That sounds like LoL isn't being identified properly.  We'll need to geta wireshark I think!
Kelly Dorset
krs360
Re: Lag on LoL
There is definitely an issue IMO.
Pretty much all day, everyday now I am experiencing sharp increases in latency, never for a prolonged period of time, but certainly enough to mess up gaming. This happens when there is also no other internet activity (Running vnstat on the gateway on a separate monitor to make sure there's nothing saturating the connection that I wasn't aware of.)
Kelly
Fixes: 9
Re: Lag on LoL
We're installing LoL one our test PC to get some wiresharks done.  Worth having a quick look at:
http://forums.na.leagueoflegends.com/board/showthread.php?t=4019902 as they've been having latency issues since August?
Kelly Dorset
All4One
Re: Lag on LoL
I had no problems last night but start of the week for a few nights I've had lag spikes which I believe are down to EUW specific servers possibly as NA has reported the same.
Kelly
Fixes: 9
Re: Lag on LoL
We've installed and played a game (and won!) and verified that it's being identified correctly in the titanium queue.
Here is our traceroute to the server we were playing on:
traceroute 95.172.65.84
traceroute to 95.172.65.84 (95.172.65.84), 64 hops max, 52 byte packets
1 10.3.1.253 (10.3.1.253) 3.937 ms 1.935 ms 1.059 ms
2 10.0.3.1 (10.0.3.1) 1.717 ms 1.597 ms 0.902 ms
3 vlan380.pbs-cr01.plus.net (84.93.216.88) 1.361 ms 1.292 ms 1.592 ms
4 gi6-8.ptp-cr01.plus.net (84.93.216.95) 1.524 ms 1.547 ms 1.430 ms
5 gi1-22.pcl-gw01.plus.net (84.93.224.49) 9.526 ms 9.330 ms 9.325 ms
6 ae3.pcl-cr01.plus.net (195.166.129.40) 9.227 ms 8.977 ms 9.430 ms
7 xe-11-1-0.edge3.london2.level3.net (212.187.201.209) 10.267 ms 9.442 ms 9.329 ms
8 ae-3-3.ebr1.paris1.level3.net (4.69.141.86) 15.805 ms 15.969 ms 16.547 ms
9 ae-71-71.csw2.paris1.level3.net (4.69.161.82) 17.914 ms
    ae-91-91.csw4.paris1.level3.net (4.69.161.90) 18.865 ms
    ae-61-61.csw1.paris1.level3.net (4.69.161.78) 21.383 ms
10 4.69.168.135 (4.69.168.135) 16.335 ms
    4.69.168.7 (4.69.168.7) 16.267 ms
    4.69.168.199 (4.69.168.199) 15.679 ms
11 global-crossing-xe-level3.paris1.level3.net (4.68.63.230) 34.788 ms 16.562 ms
    global-crossing-xe-level3.paris1.level3.net (4.68.127.98) 19.535 ms
12 lag2.ar4.fra4.gblx.net (67.16.145.242) 21.336 ms 30.041 ms 25.272 ms
13 internap.ethernet20-3.ar4.fra4.gblx.net (64.209.103.178) 22.559 ms 25.911 ms 23.404 ms
14 border1.t7-1-bbnet1.fra002.pnap.net (95.172.67.1) 25.371 ms 25.680 ms 21.821 ms
15 * * *
Are you all following similar routes?  Plusnet -> Level 3 -> Global Crossing -> gblx -> pnap
Kelly Dorset
