Keeping my troubleshoot brief as Y fronts
Ssjnecromorph
Interested
-Plays online games with naff old plusnet router for years (PS4)
-Goes away on holiday
-Returns not able to play online (NAT TYPE FAILED)
-Figured it was probably PS4 firmware - Couldnt fix -
-Buys Xbox1
-Same problem (TEREDO IP PROBLEM)
-Read Read Read Read Read
-Tried port forward
-Static public IP
-New Plusnet router
-All things through PS and XB troubleshoot
-No cigar
-Im at the point where i am looking at teredo state/some other tunnel stuff through admin command prompt but im complete novice
-surely its got nothing to do with connection between console and internet?
Plusnet tech support just keep saying its a port forward issue
-Should i just switch ISP. I honestly thought that a new router would be the answer
Thank You in advance for any response
1 REPLY 1
Solmark
Re: Keeping my troubleshoot brief as Y fronts
It seems port forwarding isn't officially supported, probably because PN support do not have the manpower to help everyone get this set up but that is a guess!
They have, however, posted some advice on port forwarding. Here is the link:-
https://community.plus.net/t5/Gaming/Plusnet-Routers-and-Port-Forwarding/td-p/1307971
Good luck with that!!
