Inside Xbox videos not streaming in the evening.
Addnan
During they day I can stream 1080p from Zune and what not, but after around 6pm I can't even stream "sentuamessage" or IGN stratigise to the Xbox. It just says loading and then after about 10mins the video starts, but then keeps buferring. My speed is fine now during the eveing. I get aroung 4.5mbs, but is my Xbox Live videos being put into a very low priorty lane or something?
5 REPLIES 5
Steve
Seasoned Pro
Re: Inside Xbox videos not streaming in the evening.
I have that problem however the majority of the time its fine,do you use the wireless adaptor?I do and i think it could be that,if not that then a network problem maybe
If life gives you lemons, make lemonade.
Addnan
I use Ethernet, so there is no problem there. It must be something to do with trafficking because it starts messing about when trafficking gets strict.
Steve
Seasoned Pro
What product are you on?
Addnan
Unlimited.
Steve
Seasoned Pro
Should be fine then as thats limited to 2 mbps at all times,why dont you move to premuim,that gives full line speed for gaming at all times with an 80gb usage and free overnight usage,thats what im on.
