If you own a console and want to play online do not buy plusnet internet!
countduckula
Recently purchased plusnet  Cry after having sky internet (which isnt great either) and cannot change the nat type tryed everythinh! i have the thompson 585 v8 router which is a pile of shit. any changes u make do not save or apply to which you set them
jim:red Avoidance of swear filter removed as per this Forum Rule mod:end
Fixes: 62
Re: If you own a console and want to play online do not buy plusnet internet!
Lets stick to facts.
There is nothing wrong with Plusnet Internet for Gaming - just buy a decent router   Roll eyes
countduckula
why should i have to buy another router should be companies priority to give customers best available products if they know there is an issue with nat and speed why still give them to customers?
Fixes: 222
my PN is great for gaming, there are guides around to help you get your console sorted.
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
countduckula
tried everythin in this forum to open the nat dmz, port etc..  if any has ne ideas be happy 2 try them instead of buying new router?
Steve
Seasoned Pro
click me
If life gives you lemons, make lemonade.
Apologies if you've already tried it but if not this is well worth a go:
http://community.plus.net/library/gaming/increasing-gaming-compatability-with-the-thomson-tg585v8-xb...
Also if you use torrents at all it's worth rebooting the router every so often (via the software interface so it's not seen as a fault by the exchange) as it seems to help the general performance.
HaydnExport
With mw3 i agree with the op , lag like crazy in every game, its ok with black ops though.........
LittleOtik
I can't fault PlusNet what so ever for gaming and I don't even have the pro add-on. Highly recommend them.  Smiley
Moncrieffe500
i cant fault plusnet either, i do have the pro add-on and have never experienced any lagg or other funny business and since ive been with plusnet a year this may i have only ever been disconnected once, no fault of there own i may add,  i would recommend them to anyone.
dick:quote
daeinera
its not plusnet's fault you're lagging on MW3, its called lag compensation and its the games fault - http://callofduty-8-modernwarfare-3.com/is-mw3-lag-compensation-penalizing-players-with-faster-conne...
or you could just google lag compensation MW3 and see the hundreds and hundreds of posts moaning about it.
