ICMP blocking
jayed
ICMP blocking
Hi, I'm having trouble connecting to Xbox LIVE and get the following message on my 360:
Your console can connect to Xbox LIVE, but your router or gateway isn't properly responding to ICMP responses
Since I've connected before, this morning in fact, I'm assuming this is a problem with Microsoft's systems rather than Plus.net or my hardware but thought I'd just check if everything is ok.
3 REPLIES 3
jayed
Re: ICMP blocking
Rebooted my router as they advise.
Turns out that Games for Windows and Windows Live are failing too.
jayed
Re: ICMP blocking
Have had a look and others are saying the same so although microsoft themselves aren't reporting it, there seems to be a problem.
Fixes: 127
Re: ICMP blocking
What router are you using and does it respond to ICMP requests? i.e can you ping your router from elsewhere on the Internet?
