I've asked for Interlevling to be turned off
farley1981
I've asked for Interlevling to be turned off via a ticket and not heard anything back for ages could a someone tell me how i would know if its been done or not?
3 REPLIES 3
Fixes: 1,473
Re: I've asked for Interlevling to be turned off
If you can get into your router and see the connection settings it would show as 'fastpath'.
What router do you have?
farley1981
i have the Thomson TG585 v7
gyre
If you go to the detail page for your DSL connection, check out the FEC errors.  If you have non-zero downstream FEC errors, you're probably interleaved.
-- gyre --
