How do I make it so someone can connect to my game server
BenG
hi, I wanted to play a private game of doom skulltag with my friend I started the server up for the game, and it all seemed to load, I could my self connect but my friend could not I set the windows firewall to allow connections but nothing, any idea.
Thanks.
4 REPLIES 4
Fixes: 1,474
Re: How do I make it so someone can connect to my game server
Did you forward any ports to allow them to connect?
BenG
I am not sure how do you do that is that in the windows firewall settings?
Fixes: 1,474
i think it runs on port 10666 so you'll need to configure your router to forward that port to the pc running the server.
BenG
Thanks I have a look at my router settings tomorrow going to sleep now tried., I let you how I get on, thanks again for the help.
