High latency on WoW, World of Warcraft
- Gaming
- High latency on WoW, World of Warcraft
02-06-2011 10:13 PM
Not sure if anyone else has experienced this after joining Plusnet but I just joined 1 day ago and raided on WoW for the first time since the switch tonight and basically it was a very frustrating experience. All my 'casts' were late or never happening until a few seconds later, and things would stop and suddenly speed up from time to time. My latency also displayed high numbers compared to my last provider.
I did do a speedtest during that time (which was pretty much the whole duration of the raid from 7pm till 10pm) and although the Download speed seemed more than fine the Upload looked extremely low, not sure if that has anything to do with it?
I was informed before joining that my package would be more than adequate to play online games so I'm pretty disappointed right now.
Anyone playing wow and who are with Plusnet experienced this tonight?
Re: High latency on WoW, World of Warcraft
03-06-2011 4:36 AM
05-06-2011 4:41 PM
05-06-2011 8:37 PM
07-06-2011 12:03 AM
Just not sure why I'm having bad latency. I even purchased the extra pro addon that's recommended by Plusnet for gaming, it did help but I still suffer from lag although it's not to the point that I see myself fastforwarded. Not sure if there's actually a fault on my line or something.
23-06-2011 10:17 AM
Maybe it would be worth raising a fault query to see if a specific issue with your connection is at fault. Good luck.
24-06-2011 11:24 AM
Is anyone else experiencing any lag on Kul Tiras this week? I'm hoping the fix on the line solved the issue and it's just the incoming patch which is causing the lag...
01-07-2011 1:26 PM
Ex-Broadband Service Manager
30-07-2011 9:59 PM
I read about something called (I think) drainpiping. I usually don't play around with computer settings, but gave it a go. Much easier than I thought and I never have a lag issue now. Coincidence? - maybe. But something happened and I'm a happy bunny.
20-08-2011 7:23 PM
23-08-2011 2:12 PM
23-08-2011 4:14 PM
Depends if you have constant high ping or just these spikes when certain things happen in game.
Hope that helps.
26-08-2011 12:17 AM
