Help with steam?
- Gaming
- Re: Help with steam?
Help with steam?
04-08-2009 8:23 AM
04-08-2009 8:28 AM
04-08-2009 9:32 AM
04-08-2009 9:41 AM
04-08-2009 4:38 PM
Navigate to to your Steam install folder, by default it's C:\Program Files\Steam
Rename 'ClientRegistry.blob' to anything eg. 'OldClientRegistry.blob'
Navigate to the C:\Program Files\Steam\config folder
Rename 'serverbrowser.vdf' to anything different like before.
This will also erase any servers in your Favourites and History so make a note of them before doing this if needed.
Start up Steam.
04-08-2009 4:58 PM
04-08-2009 6:38 PM
04-08-2009 8:05 PM
When you say the firewall is off do you mean your software firewall or Plusnet firewall or both (although i don't think our firewall would block steam on default settings).
I've seen this solution to the problem posted on a few CSS/Steam forums, not sure if it would work for you?
http://css.setti.info/servers/masterserver
04-08-2009 8:08 PM
04-08-2009 9:02 PM
04-08-2009 9:08 PM
04-08-2009 9:25 PM
04-08-2009 9:34 PM
04-08-2009 11:40 PM
You haven't mentioned whether or not you had the problem when you were with Tiscali and whether or not the 515v6 is new? You also haven't confirmed whether or not you've disabled the Plusnet Firewall?
The command you were given to run resets your TCP/IP stack and can cure some connectivity problems. Whilst I've never come across it causing problems, I've only ever used it with Windows XP.
05-08-2009 9:31 AM
