Help please
kevinneilldsl
Help please
Hello plusnet, I have a question to Ask.. My brother recently purchased a Laptop.. he's on it regularly.. So thats causeing Terrible lag for me whilst playing Fifa 12, I'm wondering if theres Any solutions at all to make my Ps3 faster and his slower?, Thanks
Kevin
6 REPLIES 6
rongtw
Fixes: 12
Re: Help please
unfortunately you will have to ask him to Disconect his laptop while you play  Wink
Kelly
Fixes: 9
Re: Help please
Is he downloading a lot?
Kelly Dorset
Ex-Broadband Service Manager
Chris
Legend
Fixes: 169
Re: Help please
If you've got the Pro add-on and he's downloading a lot then that's going to be causing the lag, Pro puts all traffic into the high priority queues so downloads and gaming will have similar priorities and therefore battle for the bandwidth available.
kevinneilldsl
Re: Help please
He's downloading nothing... He's just surfing the web..
w23
Fixes: 4
Re: Help please
There are a few routers available where you can defing 'QOS' (Prioritisation) for different connections / traffic, though these tend to be mainly the higher priced brands / models so it's potentially a big investment with no guarantee it will help.
Call me 'w23'
Blim
Re: Help please
My suggestion to you would be to ether put a net limiting program on his laptop and limit his speed to the lowest speed you get on a speed test or less(90%). Or do what I'm doing and use a second router with QoS and limit it in the same way but only connect your self to the main modem/router.
