Hawken Beta lag
tjd
Hawken Beta lag
Just downloaded Hawken open beta and when I finally get a server I'm being dropped - Connection to host lost message.
Any chance someone could see if it's being picked up as a game?
3 REPLIES 3
Gus
Re: Hawken Beta lag
Same as any game, do a wireshark capture and submit it.  Be sure to capture from the game loading and you entering the game, if you can.  Also depending on your firewall, add the games exe to its whitelist/excluded, more than likely why its failing to connect or as its just gone open beta overloaded servers.
FTTP 500 regrade from Tues 28th November
dave
Fixes: 4
Re: Hawken Beta lag
I've just downloaded it and will give it a go and see whether we're detecting it, as it's a beta game we've not got a specific entry in the database for it yet but it may be detected correctly anyway as some games are the same as others.
Dave Tomlinson
Plusnet Technology
bobpullen
Fixes: 314
Re: Hawken Beta lag
Apologies for reviving an old thread but it's the only one I could find concerning Hawken. Just a heads up that we're rolling some changes early tomorrow morning to improve the classification of the game.
