Having to swap gateways
- Gaming
- Having to swap gateways
27-04-2013 10:10 PM
Re: Having to swap gateways
27-04-2013 10:46 PM
but connection is spot on
27-04-2013 11:28 PM
28-04-2013 8:32 AM
so i try to avoid these
28-04-2013 10:47 AM
04/27/2013 19:48:21 ATM1 stop PPP
04/27/2013 19:48:03 If(ATM1) PPP connection ok !
04/27/2013 19:48:01 ATM1 get IP:212.159.16.**
04/27/2013 19:47:59 ATM1 start PPP
04/27/2013 19:47:58 If(ATM1) PPP fail : Peer terminate
04/27/2013 19:47:56 ATM1 start PPP
04/27/2013 19:47:56 If(ATM1) PPP fail : Peer terminate
04/27/2013 19:47:54 ATM1 start PPP
04/27/2013 19:47:25 192.168.2.2 login success
04/27/2013 19:45:28 ATM1 get IP:212.159.16.**
04/27/2013 19:45:28 If(ATM1) PPP fail : Peer terminate
04/27/2013 19:45:26 ATM1 start PPP
04/27/2013 19:45:25 If(ATM1) PPP fail : Peer terminate
04/27/2013 19:45:23 ATM1 start PPP
04/27/2013 19:32:25 If(ATM1) PPP connection ok !
04/27/2013 19:32:24 ATM1 get IP:212.159.16.**
04/27/2013 19:32:21 ATM1 start PPP
04/27/2013 19:31:57 ATM1 stop PPP
04/27/2013 19:31:14 If(ATM1) PPP connection ok !
04/27/2013 19:31:13 ATM1 get IP:212.159.16.**
04/27/2013 19:31:08 ATM1 start PPP
04/27/2013 19:31:04 ATM1 stop PPP
This is what I am on after all the peer terminates, pcl-ag05 so pcl must agree with my connection, well for a few days anyway until I have to swap again.
28-04-2013 4:53 PM
Its more of a problem when you cant find a gateway without lag. In some ways I'm glad I'm able to change gateway but then again its not good having to loss connection when you have things running such as servers.
28-04-2013 5:06 PM
also would be great to have a page where it shows how many are on each gateway.
28-04-2013 6:07 PM
There is a latency graph for all gateways but its not real time and you cant select what gateway your on anyway.
I did once try to connect to a specific gateway but I was dissconnecting and reconnecting for over half a hour with no luck so it pointless trying.
28-04-2013 6:26 PM
i know it wont make a difference but maybe if pn set aside a gateway for gamers this may help the issue?
28-04-2013 7:07 PM
what i would like to find out is why i can play fine for a day or so , but then especially after 17.00 i have to gateway hop for a better experience
28-04-2013 9:44 PM
Just checked and I had another peer terminate this afternoon which switched me onto pcl ag02.
I am no expert on Broadband, but isn't a peer terminate PN disconnecting me ? please correct me if I am wrong.
29-04-2013 12:39 AM
Quote from: flaminmoses i know it wont make a difference but maybe if pn set aside a gateway for gamers this may help the issue?
I think thats a great idea. not cost effective but how many ISPs can say they are 100% perfect for gaming? PN could be the first and then maybe it could be effective as more people join up.
30-04-2013 11:41 AM
30-04-2013 12:30 PM
i play till i cant and it seems i cant play more than 10 mins on fifa
bops is more varied but just as frustrating.
waiting for the contract to end so i can move.
01-05-2013 4:49 PM
Quote from: flaminmoses also would be great to have a page where it shows how many are on each gateway.
You can view this here
@Razer Is it any particular game that you have an issue with?
We're in dialogue with EA regarding FIFA and we'll be running some tests on this tomorrow and we'll update you on this.
