Good Gaming Connections ;)
St3
Aspiring Champion
Fixes: 5
Gaming is great lately Smiley
Anyone noticed better connections in gaming ?
16 REPLIES 16
w23
Fixes: 4
Re: Good Gaming Connections ;)
Have you noticed an improvement across different gateways or could you have been on a particularly good one recently?
http://usertools.plus.net/@gateway/
Call me 'w23'
Mattz0r
It must be the "1337" download speed giving it that little bit extra Wink
Gus
About the same here but I don't play ping dependant games anymore
FTTP 500 regrade from Tues 28th November
JamesM
I haven't noticed much difference TBH, but then again I have binned BF3 and only play ARMA 3 and even though ARMA 3 is great, it's like ARMA, ARMA 2 and the original Op Flash, it doesn't tend to be a smooth game at the best of times. So I am not as bothered about my connection as much as I have been with the BF series.
Blim
Yes, I couldnt tell if it was my new router but Ive been getting kills when I shoot people  Crazy
Why whats changed?
rongtw
Fixes: 12
ye its a lot better lately  Wink but still the odd slowdown between 17.00 - 20.00
Razer
I haven't been gaming for a few days, but up to that point, no, things have not been better. In fact, I had a worse spell.
Blim
I did have a day or two when things seemed very responsive but its back to normal again Sad
chrispurvey
Hi Blim,
I've taken a look over your connection and have seen quite a few bouts of disconnections;
<img src="http://ccgi.psmith12.plus.com/visradius/generated/image13709611857257.png"/>
Are these caused by you?
Blim
Yes, I bought a new router and installed it on the 6th and have been playing with it ever since. Unfortunately some settings require a restart and as it holds my pppoe connection that gets dropped.
That being sed, It rained the other day and my internet cut out. I swar its done that before and on the poll there is a connector on the main cable(running up the poll)  that has wires showing. Borken connector.
I was looking here: http://community.plus.net/ping-graphs/
And I couldnt help but notice that the day(s) that I didnt have any problems or very responsive, me and many others on PN didnt have any latency spikes on thoes days.
Could you elaborate more on that. What happend between the 6th and the 8th to make games feel more responsive?
chrispurvey
There was nothing that changed during those dates.
Thats doesn't sound right with the wires showing, as this been looked at previously?
Edit - Typo
Blim
Never. There are 3 main lines so its a 1 in 3 chance I'm connected to the one with wires showing.
chrispurvey
I can see that Chris Pettitt did quite a bit of extensive fault investigating on your line but no isues were found.
I can ge this raised to investigate what you've mentioned to see if this is affecting your connection.
chrispurvey
Hi Blim,
It would also be good to know the times when you're seeing issues and when you're not, as you mentioned your gaming was fine between the 6th and 8th. Nothing had changed our side but we'd like to take a look at how your traffic is routed when you experience issues.
So ideally, the times and date when you have good gaming and also the times when you don't.
